Recommended Alignment Specs? #2933583
06/15/21 02:25 PM
06/15/21 02:25 PM
Los Angeles, CA
JF_Moparts Offline OP
Los Angeles, CA
I'm getting my 71 Sebring aligned after installing the Borgeson box. It's been a while and I lost my notes on what a good street handling car should use for specs. Does anyone have recommendations for the caster, camber, and toe? I run 255/45's all around and have the Hotchkis uppers.
Thanks.
Re: Recommended Alignment Specs? [Re: JF_Moparts] #2933640
06/15/21 05:35 PM
06/15/21 05:35 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
0 camber, 3 positive caster, total toe 1/8.
Re: Recommended Alignment Specs? [Re: NITROUSN] #2933691
06/15/21 07:49 PM
06/15/21 07:49 PM
Los Angeles, CA
Los Angeles, CA
Thanks.
Re: Recommended Alignment Specs? [Re: JF_Moparts] #2933732
06/15/21 09:09 PM
06/15/21 09:09 PM
Sparks, Nevada
MoparMike23 Offline
MoparMike23  Offline
Sparks, Nevada
This might help…
1969 Superbee 440-6
1977 D-150 Adventurer
2000 Jeep TJ
2018 Challenger Scat Pack Shaker
2019 Ram 2500 CTD
Re: Recommended Alignment Specs? [Re: MoparMike23] #2933757
06/15/21 10:47 PM
06/15/21 10:47 PM
Los Angeles, CA
Los Angeles, CA
That's a great list. Thanks!
Re: Recommended Alignment Specs? [Re: JF_Moparts] #2933937
06/16/21 01:40 PM
06/16/21 01:40 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I agree.
A better handling car needs some amount of negative camber.
Re: Recommended Alignment Specs? [Re: Kern Dog] #2934013
06/16/21 06:08 PM
06/16/21 06:08 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
I run 1.5 degrees negative camber, 2.5 positive caster, and 1/16 to 3/32 toe in on my handling oriented mopars and my lemons valiant. For track only use the lemons car needs a touch more camber as I wear the outer edge faster.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Recommended Alignment Specs? [Re: blown340] #2934028
06/16/21 07:42 PM
06/16/21 07:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yeah, for road course use I've run 1.5-3.0 neg camber; but street, 1.0 is about max, except 2nd-gen GM F-bodies, mine liked 1.5-2.0.
The Drag Race chart caster seems odd - my Duster runs triple that, and goes straight as a string.
But you don't want your hand in between the steering wheel spokes when it unwinds in the staging lanes.
Re: Recommended Alignment Specs? [Re: topside] #2934187
06/17/21 10:42 AM
06/17/21 10:42 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I ran around 3-4* positive caster in my drag cars and set these specs up with 1" of suspension rise in the front. Ran straight and solid at triple digit speeds. Had much higher steering effort, but with 4" wide tires, it wasn't much concern.
The more body roll a handling car has, the more negative camber it may need to keep the tire upright. Softer spring rates will typically require higher camber numbers than stiffer spring rates.
