'68 3-speed wiper motor will it work in a '69 GTX?
#2933024
06/14/21 12:16 AM
06/14/21 12:16 AM
Posts: 21,546 N.E. OHIO, USA
A12
N.E. OHIO, USA
I've been looking for a 3-speed wiper motor for my '69 GTX so I could put an original Air Grabber system on it. Today I needed to move (re; clean out) some parts from the garage to a shed/12'x24' building when I came across a '68 B-body 3-speed wiper motor part number 2889982 with a 3607 date code that I forgot I had. Will this work with my '69 GTX or do I need to make some mods or is there no way it will work and I'm SOL? Of course it will need cleaned up ![rolleyes rolleyes](/ubbthreads/images/graemlins/custom/rolleyes.gif) and at some point professionally restored. At this point I'm not really concerned with the date code just want to get the AG on the car then go from there. Thanks in advance. Yeah it's a bute Clark and at this point I'm not sure if it even works....but at least it won't hit the Air Grabber ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) If it doesn't work I'll just Rain-X the windshield and drive home fast ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Mike
Re: '68 3-speed wiper motor will it work in a '69 GTX?
[Re: NITROUSN]
#2933194
06/14/21 01:10 PM
06/14/21 01:10 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
If the P/N on the crank is 2580934 and says V-speed it would just bolt in. You would need the 3sp switch also I have restored motors with the correct P/N ns1aar.com
NS1AAR
[Re: gtx6970]
#2933276
06/14/21 05:48 PM
06/14/21 05:48 PM
ns1aar
ontario calif
Part numbers for 69 A/B body would be
2983033 for cars built before Nov 68 2983116 for cars built after Nov 68 They do comingle
They are electrically and mechanically the same
NS1AAR
[Re: ns1aar]
#2934493
06/18/21 11:09 AM
06/18/21 11:09 AM
A12
N.E. OHIO, USA
Sent a pm don't know if you received it ? Thanks for the info. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Part numbers for 69 A/B body would be
[Re: gtx6970]
#2934495
06/18/21 11:12 AM
06/18/21 11:12 AM
A12
N.E. OHIO, USA
Im afraid i cant answer if it will work or not....odds are yes.
BUT.... imo. Put the right one on the car . Do it once do it right and be done
OE is probably 2983116 i think Bill where's the best place to find one? Would this wiper motor I have (posted) have a core or any value towards a '69 motor?? Thanks, Mike
[Re: A12]
#2934537
06/18/21 12:31 PM
06/18/21 12:31 PM
Posts: 21,503 It's a dry heat
gtx6970
It's a dry heat
OE is probably 2983116 i think Bill where's the best place to find one? Would this wiper motor I have (posted) have a core or any value towards a '69 motor?? Thanks, Mike Im sure it has some core value, as to how much depends on who is interested in it NS1AAR above you posted earlier he has the right one. And there are others out there restoring them or scour swap meets and or ebay
[Re: A12]
#2934735
06/18/21 11:37 PM
06/18/21 11:37 PM
ns1aar
ontario calif
They are electrically and mechanically the same PM sent
NS1AAR
