Page 2 of 3 1 2 3
Re: 543 440 Combo's [Re: Uberpube] #2783375
06/09/20 07:34 PM
06/09/20 07:34 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I just delivered a 540 race engine to a customer. If you have the block I believe the 4.25 stroke X 4.500 is the way to do it. Although this was an early Mopar mega block , we went 4.375 bore with 4.5 stoke to preserve the block for future use in bigger bores. Fully ported TF 240 heads with a roller Made 850 on the pump. Full race deal. Testing at the track has been limited with all the virus crap but early signs are promising.
Re: 543 440 Combo's [Re: Cab_Burge] #2783407
06/09/20 09:02 PM
06/09/20 09:02 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
Originally Posted by Cab_Burge
I've sonic tested 4 stock bore(4.180) 413 truck and industrial block, none of them would go safely above 4.250 bore size in my opinion shruggy
I like to have at least .160 wall thickness on both thrust surfaces after boring up work
Never sonic checked that 413 block myself but I saw an operation ONE BESTER than that !
When I was west side down State Michigan there was a guy I knew who had a BUSTED UP block ......
Who pulled up sections of that block.... I saw areas in the cylinder walls - ON THAT BLOCK - that were near .250 !
Re: 543 440 Combo's [Re: dOc …] #2783441
06/09/20 10:22 PM
06/09/20 10:22 PM
4.170+.250=4.420, correct
4.420-.160=4.260, hence me choosing to bore them to standard 426W and 383 bore sizes for pistons and ring choices up
Re: 543 440 Combo's [Re: dOc …] #2785796
06/15/20 05:51 PM
06/15/20 05:51 PM
Carson City, NV
440sourcedotcom Offline
Carson City, NV
Originally Posted by Doc Fiberglass..
Originally Posted by 440sourcedotcom
Originally Posted by fast68plymouth
I’m not sure which combo the “543” is.
4.375 x 4.500 is 541.2
4.380 x 4.500 is 542.4
4.500 x 4.250 is 540.7
4.440 x 4.375 is 541.9
Our 543 kit is a 4.500 stroke x 4.380" bore, which equals 542.43 cubic inches. We offer pistons for that kit in .060" over, so we usually rate the cubic inches at the largest available bore size. And we did round up by .57 hundredths of a cubic inch.
Which block do you recommend? Any consideration on the industrial 413,block ? What’s the minimum wall thickness? Do you offer an assembled short block ?
Most all blocks are the same and work great. If you haven't read it, check out our article on engine blocks here: http://www.440source.com/blockinfo.htm
We've found the 413 industrial blocks to have very thick cylinder walls (over .400") so they usually support boring out to a 440 size. But you should always sonic check the specific block you are using, and make sure it has enough thickness. The factory "spec" for cylinder wall thickness is .250". We usually don't like to see less than .180" or so.
Re: 543 440 Combo's [Re: 440sourcedotcom] #2807412
08/10/20 07:34 PM
08/10/20 07:34 PM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
Bump to see if anyone has built one.....in a stock block...
Re: 543 440 Combo's [Re: Dragula] #2807469
08/10/20 09:37 PM
08/10/20 09:37 PM
gregsdart Offline
gregsdart  Offline
The one i posted about earlier in this thread was actually a 426 wedge block bored .100 to 4.350 and a stock rod journal size of 2.375 using 6pak rods and a 4.500 stroke. At 535 cubes with 906 heads it took a .750 lift 286 @ .050 roller to make power above 5700 rpm.
I see little point in pushing a 4.5 stroke stock block above5500 to 6000 due to strength issues. Same with power. Stay at about 650 hp and enjoy the torque.
Re: 543 440 Combo's [Re: gregsdart] #2807482
08/10/20 09:49 PM
08/10/20 09:49 PM
I am looking to go 5's.....And what my best options might be..
Re: 543 440 Combo's [Re: Dragula] #2807511
08/10/20 11:16 PM
08/10/20 11:16 PM
gregsdart Offline
gregsdart  Offline
5.90 in the 1/8th is about 9.23 in the 1/4 and at 3000 race weight will take about 750 hp. So i would definately find a good 400 block and go with a 512 with ported large port heads. The easeist route is 14.5 + compression, mechanicl fuel injection, alcohol and a rollercam similar to an Isky RR735. Plan your valvetrain carefully. I needed more spring than isky called for with that cam. You might hit the number at 3000 lbs with that recipe and bowl porting only, but it will be close. I went 9.34 at 143 mph in Minnesota (1800 da?) With bowl ported 440-1 heads, 13/1, 499 cubes, 283/290/110 roller cam of .760 lift. Alky injected, shifting 6800.
Re: 543 440 Combo's [Re: gregsdart] #2807597
08/11/20 09:56 AM
08/11/20 09:56 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
To go 9.20’s at 3000lbs will require a little over 700hp, uncorrected, as it sits on the starting line.
So, you’d be shooting for 770-800 STP hp on the dyno.
Probably not the best plan for a stock block.
Making the power isn’t that hard.
Getting the stock block to live at that power level is the challenge.
I wonder how many have built stock 440 block combos that make 750+ hp(especially long stroke combos)........ and race them regularly(as in..... a typical weekly bracket program).
Re: 543 440 Combo's [Re: gregsdart] #2807599
08/11/20 10:02 AM
08/11/20 10:02 AM
Mo.
racerx Offline
racerx  Offline
Mo.
@ what weight ? wave
Re: 543 440 Combo's [Re: racerx] #2807750
08/11/20 03:53 PM
08/11/20 03:53 PM
gregsdart Offline
gregsdart  Offline
It has been done.
Race wieght was 3000 lbs. That 499 lived a good long life and was sold and hit with nitrous for a couple seasons.
Re: 543 440 Combo's [Re: gregsdart] #2807808
08/11/20 06:33 PM
08/11/20 06:33 PM
Been 6.02 so far at 3000lbs...with my little 400/512....It just seems like it does not pull as hard down track as my previous 440/512.....Which got me thinking about the bigger strokers they offer...The 526 and then the 543....Seems like my current combo with 20 more Hp would make it...
I just don't know about a 4.5 stroke in a stock block...
Re: 543 440 Combo's [Re: Dragula] #2807810
08/11/20 06:39 PM
08/11/20 06:39 PM
I wouldn't learn either tsk grin AKA don't stress the main webbing in a stock block, even with a girdle twocents
Re: 543 440 Combo's [Re: Dragula] #2808058
08/12/20 12:19 PM
08/12/20 12:19 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I take back what I said a few months ago about the 4.250 stroke motors not making good power as mine did not at the time and I hadn’t seen anyone else impressing me with one. I am now impressed with the output of the 511/512 combos. You guys are making good power and going impressively fast with them. I found a key ingredient in the 511 combo, compression. I gained almost 4 tenths with a 1.25 point increase also tightening up the quench to .040 at the same time.
Re: 543 440 Combo's [Re: gregsdart] #2808175
08/12/20 05:40 PM
08/12/20 05:40 PM
Mo.
racerx Offline
racerx  Offline
Mo.
It has been done.
Thanks up ….sounds real close to my combo but I have a little more cubes with more race weight and less cam and the i'v been is 600.2.
Re: 543 440 Combo's [Re: racerx] #2808293
08/13/20 01:55 AM
08/13/20 01:55 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
I have a 543 with a stock 440 block, aluminum caps and a girdle. Victor heads, solid roller cam, 1050 dominator It is in a 68 barracuda with a 4 speed and a dana 60 with 4.56's.
The car is apart right now, and I have been 2 busy building other peoples cars to work on my own junk. Maybe sometime next year it will be done. AND yes i know ill break parts.
I spun it to 6500 RPMS before with a 727 behind it and 4.10s in the rear on 26" tall tires. Just on the street and no traction.
I don't plan on taking it to much over 5k rpms, and I may add a little boost to it, small turbo and EFI keep the rpms down even more but make lots of power.
Re: 543 440 Combo's [Re: 8urvette] #2854086
12/01/20 11:24 PM
12/01/20 11:24 PM
My parts arrived, and I would like to get back to this thread and see what HP you guys are at with one of these......I have Indy big easy 325 heads, so I am curious how far this will go. What kind of cam specs should I be shooting for? My little .680 lift 280 duration is staying with my 512/400 so I am going to need a new cam. I like the 280 duration, maybe more lift?
I will be in the 5's this year, one way or another...
Re: 543 440 Combo's [Re: Dragula] #2854216
12/02/20 10:46 AM
12/02/20 10:46 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
What do you guys think of this combo in a stock block with a girdle?
Since you asked and based on your stated goal...I think Dwayne (and some others) answered your question but it went unrecognized? The extra stroke will help add compression but you can do the same with a piston. If you are set on changing the combination of parts...I'd put the longest rod you can on a crank 3.75 to 4" and SPIN it for power make the bobweight under 2000 gms on a 2.1 pin. Put BETTER work and parts in your top end and it'll make the same power at 451" as it will at 541" but the bobweight and longer rod will help it live.
Re: 543 440 Combo's [Re: HardcoreB] #2854347
12/02/20 01:51 PM
12/02/20 01:51 PM
I guess we will see...
Re: 543 440 Combo's [Re: HardcoreB] #2854349
12/02/20 01:55 PM
12/02/20 01:55 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have the 541 440source deal but used GRP 7.1 rods.
Runs 5s with indy -1 in my Valiant. I don't run it much since I got Ka-Blue-E running.
Its strong but not huge numbers over the 500ci shortblock I replaced it with.
Page 2 of 3 1 2 3
