Tail stripe placement 69 Dodge Charger #2932836
06/13/21 02:13 PM
06/13/21 02:13 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
I am looking for measurements for a 69 Charger tail stripe. I found the factory diagram but it is for 68 and they are different. If someone can measure a car if possible would be great. I know they should be centered over the side light opening. Measurements at top of quarter end to stripe would help. Also at trunk center tip to stripe and trunk side tip to stripe.Having some reference points would give me a bit more confidence.
Re: Tail stripe placement 69 Dodge Charger [Re: NITROUSN] #2932878
06/13/21 04:21 PM
06/13/21 04:21 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Paging Rick Ehrenberg...
Or maybe look through the Mopar Action archives for the '69 factory schematic ?
Re: Tail stripe placement 69 Dodge Charger [Re: topside] #2932976
06/13/21 09:05 PM
06/13/21 09:05 PM
Norfolk County , Ontario
WORKER_BEE Offline
WORKER_BEE  Offline
From what I've seen on original paint cars, the stripe is a little off from being centered to the reflector opening.
My Charger was painted once in the early 80's and by today's standards it's pretty mediocre. On a good note there are remnants of the original stripe on some areas.
The first photo is hard to see but the measurement is 3-1/8".
1969 Super Bee Six Pack
1969 Charger R/T SE
1968 Crown Coupe
Re: Tail stripe placement 69 Dodge Charger [Re: WORKER_BEE] #2932978
06/13/21 09:08 PM
06/13/21 09:08 PM
WORKER_BEE Offline
WORKER_BEE  Offline
This photo is at the bottom of the quarter panel and the measurement is almost 15/16".
1969 Charger R/T SE
1968 Crown Coupe
Re: Tail stripe placement 69 Dodge Charger [Re: WORKER_BEE] #2932982
06/13/21 09:12 PM
06/13/21 09:12 PM
WORKER_BEE Offline
WORKER_BEE  Offline
Here's a back in the day pic from the web showing the stripe not centered to the reflector.
1969 Charger R/T SE
1968 Crown Coupe
Re: Tail stripe placement 69 Dodge Charger [Re: WORKER_BEE] #2932986
06/13/21 09:17 PM
06/13/21 09:17 PM
WORKER_BEE Offline
WORKER_BEE  Offline
This is an unrestored original.
1969 Charger R/T SE
1968 Crown Coupe
