Re: Sniper EFI bad injector
[Re: TJP]
#2933985
06/16/21 04:37 PM
06/16/21 04:37 PM
Posts: 4,405 Michigan
MarkZ
Worthy
Worthy
Alright, spoke too soon I guess. That hole wasn't spewing gas because the injector wasn't firing. The first time I put it back together one of the pins didn't line up properly. The plug itself is just a couple of pins free floating - no molded plastic to keep them centered. After assembling it a second time it started spewing gas out the barrel that had the original problem. This is after swapping the injectors front to back. Has to be electrical, but I couldn't find anything glaringly wrong with it. Back to Holley it goes. Already have a return label. Thank you everyone for your help.
[Re: MarkZ]
#2934064
06/16/21 09:08 PM
06/16/21 09:08 PM
Posts: 15,315 Omaha Ne
TJP
Omaha Ne
Alright, spoke too soon I guess. That hole wasn't spewing gas because the injector wasn't firing. The first time I put it back together one of the pins didn't line up properly. The plug itself is just a couple of pins free floating - no molded plastic to keep them centered. After assembling it a second time it started spewing gas out the barrel that had the original problem. This is after swapping the injectors front to back. Has to be electrical, but I couldn't find anything glaringly wrong with it. Back to Holley it goes. Already have a return label. Thank you everyone for your help. So I'm a bit confused ( not unusual LOL) After assembling it a second time it started spewing gas out the barrel that had the original problem Is that with another injector or the same one? I assuming a different Injector as you're now suspecting an electrical issue. SNIPER earlier mentioned he believes they are fired off a ground signal. If so, just out of curiosity, I might try to disconnect the signal wire at the ECU to see if the injector shuts off. That would confirm 2 things. It is the ECU, and that you do not have a pinched wire or other erroneous problem.
[Re: MarkZ]
#2934180
06/17/21 10:24 AM
06/17/21 10:24 AM
Posts: 3,414 Toronto
mshred
Toronto
I've got about $1500 tied up into mine between the pump, unit and fittings. It's been on the car for three years now, so well outside warranty. What little I've been able to find it looks like the injectors are proprietary and Holley won't sell them separate. I really don't want to send this back to them for service. Car has been down long enough. Was this the first time firing up in the 3 years you have had it?
[Re: mshred]
#2934246
06/17/21 01:06 PM
06/17/21 01:06 PM
MarkZ
Worthy
Worthy
I've got about $1500 tied up into mine between the pump, unit and fittings. It's been on the car for three years now, so well outside warranty. What little I've been able to find it looks like the injectors are proprietary and Holley won't sell them separate. I really don't want to send this back to them for service. Car has been down long enough. Was this the first time firing up in the 3 years you have had it? No, it was running in the fall. Originally took it apart to swap valve springs as the builder had the wrong ones in place. Sniper unit sat on the top of the car over the winter.
[Re: TJP]
#2934249
06/17/21 01:13 PM
06/17/21 01:13 PM
MarkZ
Worthy
Worthy
Alright, spoke too soon I guess. That hole wasn't spewing gas because the injector wasn't firing. The first time I put it back together one of the pins didn't line up properly. The plug itself is just a couple of pins free floating - no molded plastic to keep them centered. After assembling it a second time it started spewing gas out the barrel that had the original problem. This is after swapping the injectors front to back. Has to be electrical, but I couldn't find anything glaringly wrong with it. Back to Holley it goes. Already have a return label. Thank you everyone for your help. So I'm a bit confused ( not unusual LOL) After assembling it a second time it started spewing gas out the barrel that had the original problem Is that with another injector or the same one? I assuming a different Injector as you're now suspecting an electrical issue. SNIPER earlier mentioned he believes they are fired off a ground signal. If so, just out of curiosity, I might try to disconnect the signal wire at the ECU to see if the injector shuts off. That would confirm 2 things. It is the ECU, and that you do not have a pinched wire or other erroneous problem. Had the original problem of the rear passenger barrel blowing fuel all over the place. Swapped injectors front to back on Andy's suggestion and observed it wasn't doing that anymore. Upon further inspection though I noticed the passenger rear injector wasn't firing at all. Turned out I didn't plug it in correctly (pins float and aren't held in place in a molded plug). After I corrected that mistake the original problem came back with the passenger rear barrel blowing fuel again. This was with the injectors being swapped, so I can only conclude now it's an electrical fault since the issue didn't follow the injector.
[Re: TJP]
#2938959
07/02/21 09:38 AM
07/02/21 09:38 AM
MarkZ
Worthy
Worthy
Just an update. Holley called yesterday and repaired the unit. Faulty injector driver. Cost me $250 seeing as how it was out of warranty. I'm happy though. Only took them a week to turn it around and they covered shipping there and back.
[Re: BDW]
#2939093
07/02/21 06:27 PM
07/02/21 06:27 PM
MarkZ
Worthy
Worthy
Glad you got it fixed. Price seems a little high? How old is the system, and what does a new complete Sniper cost? New unit is $1k. Mine is three years old. The tech said they replaced the logic board too.
