Re: 70 Cuda tire options
[Re: gtx6970]
#2932689
06/13/21 01:28 AM
06/13/21 01:28 AM
Posts: 17,529 Las Vegas, NV
6bblgt
Las Vegas, NV
Without the build sheet is there really any way to tell for sure what tire and wheel combination any particular car came with , outside of the standard tire / wheel option???? there are a number of original details that can point to possible original tire/wheel combinations (cars were built by people and any of the following could've happened by mistake) 1970 'cuda:red painted brake drums indicate "ROAD" or "RALLYE" wheels tire pressure decal "62" F70-14s VS. "59" E60-15s, etc. speedometer pinion 36 - F70-14s VS. "37" E60-15s (with 3.55s) lower control arm bumper spacers with 15" tires space saver spare was a "mandatory OPTION" with 15" tires & OPTIONAL with 14" tires (& stud to mount spare in trunk was in different position full size VS. space saver)
[Re: fastmark]
#2932720
06/13/21 08:39 AM
06/13/21 08:39 AM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
Mark,
If you do decide you want 14” plain wheels, I still have that date code matched set of 5 I got from you several years ago.
Tom
68 Charger 70 Cuda
[Re: 6bblgt]
#2932734
06/13/21 09:44 AM
06/13/21 09:44 AM
Posts: 4,762 Florida
BDW
Without the build sheet is there really any way to tell for sure what tire and wheel combination any particular car came with , outside of the standard tire / wheel option???? there are a number of original details that can point to possible original tire/wheel combinations (cars were built by people and any of the following could've happened by mistake) 1970 'cuda:space saver spare was a "mandatory OPTION" with 15" tires & OPTIONAL with 14" tires (& stud to mount spare in trunk was in different position full size VS. space saver) Any pics for the different hold down location? Different floor pan or just a different / hole that could be used?
[Re: BDW]
#2932753
06/13/21 11:03 AM
06/13/21 11:03 AM
Posts: 21,534 It's a dry heat
gtx6970
It's a dry heat
Without the build sheet is there really any way to tell for sure what tire and wheel combination any particular car came with , outside of the standard tire / wheel option???? there are a number of original details that can point to possible original tire/wheel combinations (cars were built by people and any of the following could've happened by mistake) 1970 'cuda:space saver spare was a "mandatory OPTION" with 15" tires & OPTIONAL with 14" tires (& stud to mount spare in trunk was in different position full size VS. space saver) Any pics for the different hold down location? Different floor pan or just a different / hole that could be used? Different bolt length in a different mounting location on same bracket
[Re: FC7cuda]
#2932789
06/13/21 12:18 PM
06/13/21 12:18 PM
Posts: 6,444 Abilene, Texas
fastmark
Abilene, Texas
Mark,
Tom Thanks. I’ll keep that in mind.
[Re: BDW]
#2932843
06/13/21 03:52 PM
06/13/21 03:52 PM
6bblgt
Las Vegas, NV
Any pics for the different hold down location? Different floor pan or just a different / hole that could be used? same bracket - different stud in a different location "space saver" VS. full size spare in a E-body ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) (convertible used a different bracket welded to the trunk floor)
[Re: gtx6970]
#2932853
06/13/21 04:12 PM
06/13/21 04:12 PM
6bblgt
Las Vegas, NV
Dan. Applying same question to a 1970 challenger 340 as example. Wasn't the E60.15 tires standard equipment? the original offering (mid-September '69) of a 340 package for the Challenger was expensive at ~$250 & included the E60-15s, but had W21 wheels & W34 spare as additional "mandatory OPTIONs" (another ~$56) the OPTION package was re-vamped around late-October & the 15" tires/wheels were no longer included, but they were on the OPTION list Using my 1966 Satellite as another. Wasnt the 7.75.14 blue streak the only avail tire....or were there options for it as well. I know there were no 15" tire options in 1966 correct?
Correct, there wasn't a big OPTION list on '66 model year cars - HEMI OPTION included 7.75-14 "blue streaks" on 14x5.5" wheels Satellite included bucket seats, console, full wheel covers w/spinner and other equipment exclusively (only '66 Plymouth b-body with these items)
[Re: gtx6970]
#2932870
06/13/21 05:01 PM
06/13/21 05:01 PM
6bblgt
Las Vegas, NV
And using a 68-70 B body for example , they had the crayon markings on the bottom of the decklid . Was this the same on other car lines ? AFAIK b-body ONLY at LYNCH RD. Detroit, MI assembly plant
[Re: 6bblgt]
#2933625
06/15/21 04:46 PM
06/15/21 04:46 PM
Posts: 203 Alabama
David1971
Alabama
the OPTIONAL E60-15s are roughly ~3/8" shorter in diameter & ~7/8" wider than the STANDARD F70-14s (at least the reproductions - original tires may differ slightly) interesting window sticker ![work work](/ubbthreads/images/graemlins/custom/work.gif) did the original owner get a mandatory "space saver spare tire" for FREE? When I purchased the Cuda about 2 years ago, there was no spare in the trunk. I do not not have the build sheet in order to verify the "space saver"....which is what it should have came with from Hamtramck. The short style stud is in the trunk at the space saver location.
[Re: Little Detroit]
#2933629
06/15/21 05:00 PM
06/15/21 05:00 PM
Posts: 203 Alabama
David1971
Alabama
those were not the only details of the 14 inch tire , they also had a different Jack hook. same number , but the jack hook had no hole in the side to slide over the the spare tire stud. the jack hook was mounted under the full size spare tier pinched betweened the tire and the trunk floor. see pic. Are you referring to the jack hook on 14 inch rimmed B bodies only? David
[Re: fastmark]
#2933851
06/16/21 09:11 AM
06/16/21 09:11 AM
Posts: 1,084 Long Island, NY
70plymA34
Long Island, NY
What would be the std wheel and tire option on a 70 440 4 barrel Cuda with auto trans and option 3.55 suregrip package. The previous owner bought the car in 76 and I had a bunch of 14” rally’s that came with it but it always had ET mags since he bought the car. No buildsheet since it’s an LA built car. Nothing on the tag to help either. Im in the same boat as you with an LA Built 440-4 Cuda. Mine is a 4.10 Super Track Pack and no buildsheet. My car originally came the F70-14 White Line Tires. The original owner sent me a pic from late 69 showing the car when it was a month old with the original tires and rally wheels. good luck with your car.
Super Commando
