Time for a new driveshaft #2930943
06/07/21 03:43 PM
06/07/21 03:43 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
70 Barracuda is going to get a new bullet and rear end. The car has not been gutted and won't be a lightweight. What do I need for a driveshaft? What is a good diameter, wall thickness and material to specify? I am not class racing so no need to get exotic. Probably use 1350 joints. What kind of yokes are normally recommended for something like this?
Re: Time for a new driveshaft [Re: GomangoCuda] #2930954
06/07/21 04:10 PM
06/07/21 04:10 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I got mine from Dr Diff(Cass). Its by strange. If I remember correctly its 3.5" steel. I did not upgrade to the billet yoke. Mine uses 1350 ujoints. Been running it in my 4000lb plus wagon for 6 yrs. Not the fastest runs 7.01 in the 1/8th. No issues
Ok
Re: Time for a new driveshaft [Re: cudatom] #2930959
06/07/21 04:18 PM
06/07/21 04:18 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
I had mine made by a shop that build/repairs ds for heavy trucks. They also build shafts for Pro Stick cars. IIRK it cost about 260.00 with 1350 joints included/ installed.
America First!
Re: Time for a new driveshaft [Re: GomangoCuda] #2930987
06/07/21 05:08 PM
06/07/21 05:08 PM
AndyF Offline
AndyF  Offline
Strange Engineering will make one for you from premium parts. You can check with a local driveshaft place too and maybe find something made from cheaper materials.
https://www.strangeengineering.net/product/seamless-chrome-moly-drag-racing-driveshaft.html/
Re: Time for a new driveshaft [Re: AndyF] #2931036
06/07/21 07:17 PM
06/07/21 07:17 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I have good luck with Denny’s . They also have lifetime free labor to change the u joints and shorten it if you ever change rear or trans . Can’t beat the nitrous ready shaft he sells . Almost and place that builds you an1350 shaft will sell you a strange or sonnax trans yoke . This is one thing I like overkill on , last thing you want with any car is a broken or twisted shaft beating the bottom of your car !
....BAD A$$ STREET CAR.....
Re: Time for a new driveshaft [Re: GomangoCuda] #2931167
06/08/21 08:02 AM
06/08/21 08:02 AM
an8sec70cuda Offline
I have a Mark Williams billet steel 1350 trans slip yoke and a billet 1350 yoke on the rear from Moser. I had a local big truck driveline shop make me a 3" diameter steel driveshaft w/ what they call their "thickwall" tubing which I believe is .090" thick. Also using Spicer 1350 U joints.
It's been fine for a long time, but I don't race nearly as much as I used to. It's made plenty of deep 5 sec 1/8 mile passes, 8 sec 1/4s at nearly 3900 lbs.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Time for a new driveshaft [Re: n20mstr] #2931252
06/08/21 12:57 PM
06/08/21 12:57 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Got a few made locally for lower HP cars with no problems. Have used Dennys for the last couple, his prices are reasonable and good quality parts.
The only Carbs I care about are under the hood!
Re: Time for a new driveshaft [Re: Azzkikrcuda] #2931266
06/08/21 01:25 PM
06/08/21 01:25 PM
moparx Offline
moparx  Offline
just make sure the place you decide to use does high speed balancing.
around here, the local truck garage[s] just do low speed balancing, and at times, this works out. other times, however, vibration issues arise, and i blame it on the balance.
just my opinion. your mileage will vary.
beer
Re: Time for a new driveshaft [Re: moparx] #2931303
06/08/21 02:34 PM
06/08/21 02:34 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
beer
This. I've had shafts made locally that were not quite right. Maybe OK in a street rod or cruiser that rarely sees over 3000RPM. Not so much at 7K.
Strange. Mark Williams, One of the other top shelf shops that do parts for race cars, not dump trucks.
Re: Time for a new driveshaft [Re: CMcAllister] #2931309
06/08/21 02:53 PM
06/08/21 02:53 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Measure center to center length, approximate trap speed to calculate driveshaft rpm and look at a driveshaft critical speed chart.
Re: Time for a new driveshaft [Re: INTMD8] #2931322
06/08/21 03:24 PM
06/08/21 03:24 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
I will NEVER use another Strange Driveshaft, I had a driveshaft vibration @ 80mph & above, called them & they ONLY spin them 500 rpm, I got one from Mark Williams & it is now SMOOTH as glass.
Re: Time for a new driveshaft [Re: CSK] #2931489
06/08/21 10:37 PM
06/08/21 10:37 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
I love Strange but not for driveshafts. 20 years ago i was in the market for a new driveshaft for the race car. Its a long shaft. Was going to buy a CM from Strange. Don't remember if it was a 3 or 3 1/2". Was about to buy it and asked what the critical speed was of the shaft. They could not tell me. Called Mark Williams and they said you can't use that shaft. Ended up with a 4" MS shaft from MW and could not be happier. They balanced it somewhere around 7000 rpm.
Re: Time for a new driveshaft [Re: markz528] #2931711
06/09/21 05:01 PM
06/09/21 05:01 PM
napa ca
P
procharged 484 Offline
P
napa ca
Bought a 3.5 inch cm from strange with billet ends and billet yokes for a 70 challenger and they made it 0.600 short twice . I had to pay shipping for their mistake . Never again for driveshaft's !
Re: Time for a new driveshaft [Re: GomangoCuda] #2931718
06/09/21 05:21 PM
06/09/21 05:21 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've had good luck with this local company but have heard mixed reviews in recent years.
https://www.dynotechengineering.com/drive-shaft/drive-shafts
Rich H.
Esse Quam Videri
Re: Time for a new driveshaft [Re: ZIPPY] #2931724
06/09/21 05:49 PM
06/09/21 05:49 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Martin spring and driveshaft right here in Kalamazoo does a great job with driveshafts and high speed balances them too. Very reasonable, never had an issue or hurt one with anything i have had
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Time for a new driveshaft [Re: procharged 484] #2931869
06/10/21 07:44 AM
06/10/21 07:44 AM
These bad reviews of Strange backs up what I've thought of them for a long time. I've seen a lot of broken and twisted Strange axles over the years...stuff that shouldn't have broken.
CHIP
Re: Time for a new driveshaft [Re: GomangoCuda] #2932282
06/11/21 01:36 PM
06/11/21 01:36 PM
Has anybody used one of the Nascar driveshafts for sale on eBay?
Some are about the right length. 4" diam, 1350 joints, some .065 wall and some .083 wall steel. Made by Dynotech.
