Re: Helicoils for spark plug threads ?
[Re: hemienvy]
#2931655
06/09/21 02:37 PM
06/09/21 02:37 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
I wouldn't waste the time on it. Just don't over tighten them and use anti-seize.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: fbs63]
#2934464
06/18/21 09:48 AM
06/18/21 09:48 AM
Posts: 1,611 westerly, ri. usa
440lebaron
westerly, ri. usa
WD-40, metallic anitseize can short out spark
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: fbs63]
#2934504
06/18/21 11:29 AM
06/18/21 11:29 AM
Posts: 43,282 Bend,OR USA
Cab_Burge
I wouldn't waste the time on it. Just don't over tighten them and use anti-seize. I second this. Me three, I use Champion brand liquid graphite base aircraft spark plug lube on all the plugs I put into aluminum race heads now I am careful to not get any of it on the plug part that is in the combustion chambers, on the plug threads only
[Re: Cab_Burge]
#2934530
06/18/21 12:14 PM
06/18/21 12:14 PM
Posts: 10,752 North Dakota
6PakBee
North Dakota
Anti-sieze, just like Brylcreem, a little dab'll do ya!
[Re: 440lebaron]
#2934558
06/18/21 01:05 PM
06/18/21 01:05 PM
Posts: 19,577 north of coder
moparx
WD-40, metallic anitseize can short out spark i'm not doubting this statement, but i have been using copper hi-temp anti-seize on plug threads for over 40 years, and have never had this happen to me. i use it like bryle cream as stated : "a little dab 'll do ya".........
[Re: moparx]
#2934765
06/19/21 07:51 AM
06/19/21 07:51 AM
Posts: 173 Sticky South
Rodenteliminator
Sticky South
My thought is helicoils are a one time use repair, the helicoil doesn’t always match the length of the threads of your part but will hold torque but any removal or restart of your bolt or in this case spark plug your are taking a chance, I use 10 to 15 helicoils daily for repairs in steel and aluminum and the aluminum is already a hit and miss for the higher torque applications. I also use solid inserts that we install and use Red Thread Locker and let set for 24 hours for the bigger much higher torque applications (75 ft lbs and higher ) but never any thread locker on a helicol.
Sorry honey I spent the rent
[Re: Rodenteliminator]
#2934770
06/19/21 08:40 AM
06/19/21 08:40 AM
Posts: 1,385 Az
69hemibeep
Az
Do a little research on repair kits for the Ford V10. Several different methods.
1969 Hemi Roadrunner 2nd owner
[Re: MoonshineMattK]
#2935205
06/21/21 08:25 AM
06/21/21 08:25 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
If you're gonna replace the threads, use something like this. I wouldn't be replacing anything until it HAD to be done though.
