oil pan- gasket maker or just gasket? #2931100
06/07/21 09:51 PM
06/07/21 09:51 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Pulled my 440 block to fix a small oil leak among a few other issues. The question is: Do i use cork gaskets between windage tray and oil pan and block girlde to windage tray, or Do i just use gasket maker and no gasket?
As it was I have a block girdle, windage tray and obviously oil pan.
I had the girlde RTV'd to the block with no gasket, then cork gasket RTV on both sides to windage tray and cork gasket with RTV on both sides to oil pan. I still had a few small oil seep type leaks. Enough to make a few drops on the ground.
What is the BEST way to seal the bottom end of a RB mopar motor???
Re: oil pan- gasket maker or just gasket? [Re: 8urvette] #2931119
06/07/21 11:00 PM
06/07/21 11:00 PM
PA
moparacer Offline
moparacer  Offline
PA
I have never used a girdle, but I am a big fan of the superformance pan gaskets. I have reused them over and over between the block, windage tray, and pan. Only place I put a small dab of silicone is at the corners where the timing cover meets the block, and the rear seal at the back.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: oil pan- gasket maker or just gasket? [Re: moparacer] #2931121
06/07/21 11:09 PM
06/07/21 11:09 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
iagree
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: oil pan- gasket maker or just gasket? [Re: BloFish] #2931122
06/07/21 11:10 PM
06/07/21 11:10 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Where do I buy them?
Re: oil pan- gasket maker or just gasket? [Re: 8urvette] #2931126
06/07/21 11:25 PM
06/07/21 11:25 PM
PA
moparacer Offline
moparacer  Offline
PA
Re: oil pan- gasket maker or just gasket? [Re: moparacer] #2931159
06/08/21 07:13 AM
06/08/21 07:13 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Clean surface with Ultra Grey will seal easily with no leaks. I still use a generic gasket with it. Why? Because its very difficult to remove the pan. With a gasket it rips when prying it off. Then the pan can be removed. The valley tray, motor plate, water pump, headers, get nothing but Ultra Grey.
Doug
Re: oil pan- gasket maker or just gasket? [Re: dvw] #2931253
06/08/21 01:02 PM
06/08/21 01:02 PM
PA
moparacer Offline
moparacer  Offline
PA
Doug
I used to do that and and I got tired of the cleanup when everything was apart. Ultra Grey is almost like an adhesive too. Sometimes its hell to get things apart when you use it. With the Superformance, you can silicone it, pull it apart later and it never rips, and the small dabs of silicone clean right off.
When I switched to the Superformance, I asked the gasket where it had been all my life.... laugh2
Re: oil pan- gasket maker or just gasket? [Re: moparacer] #2931375
06/08/21 05:33 PM
06/08/21 05:33 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
With my World block i seem to have a resonance causing the pan bolts to loosen up , even with loctite
i have been using the standard Felpro , but very thin and dont seem to like retightening too often . I have used a Milodon before and like the look of it bit thicker . I currently have a Felpro 1834 to try , its a steel core type and uses a silicon material (?) . Felpro says NO sealant . It is thick and notes as being for KB top fuel . I think i read somewhere NHRA mandates this style .
Its a pain to pull the road/race pan so it may wait a little while . Have to trim lower trans bell a little to help.
Noone here in Aus carries Superformance , still wating for Mancini on my last order . Better call Todd .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: oil pan- gasket maker or just gasket? [Re: moparacer] #2931382
06/08/21 05:56 PM
06/08/21 05:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
I like, use and recommend the SCE black rubber cork thick combo on the steel centers up scope
I wish I had a part number for you but I don't whiney
Re: oil pan- gasket maker or just gasket? [Re: moparacer] #2931390
06/08/21 06:12 PM
06/08/21 06:12 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Originally Posted by moparacer
I am so glad I opened this thread. They have the M1 tunnel ram top gaskets!
I thought for sure I was going to be cutting up a couple cereal boxes.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: oil pan- gasket maker or just gasket? [Re: hp383] #2931478
06/08/21 10:21 PM
06/08/21 10:21 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Greg has nice stuff.... his carb gaskets are da’ chit! Have them on both carbs and the bowls and metering blocks still fall off when the bolts are loosened.
