Re: Quick release stock steering column
[Re: Since1822]
#2931077
06/07/21 08:41 PM
06/07/21 08:41 PM
Posts: 4,690 On the parachute mount
n20mstr
I bought a coupler spike that slid over the stock spline , then you put a lock nut to hold it on . Then got the coupler and booted it to a grant wheel . I bought the spline coupler from jegs . Itβs heavy but works good
....BAD A$$ STREET CAR.....
[Re: Since1822]
#2931254
06/08/21 01:03 PM
06/08/21 01:03 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I got the splined part welded to a big body washer and drilled holed to mount on the 3 factory holes.The center shaft has 1/2" 20 thread like a lug nut so I used a shanked lug nut and cut it short to fit the center length needed and trimmed the acorn on top to fit under the steering wheel.
[Re: Clanton]
#2931304
06/08/21 02:37 PM
06/08/21 02:37 PM
Posts: 11,645 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Grant made/makes kits for many factory columns. SFI rating may be an issue if it needs to pass tech somewhere.
