Re: Before I crash this car..
[Re: Sammy]
#2930904
06/07/21 01:55 PM
06/07/21 01:55 PM
Posts: 10,044 MN
JERICOGTX
MN
Did you remove the upper A arms at any point? Might be OK IF you did not, but I'd do it anyway.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2930915
06/07/21 02:34 PM
06/07/21 02:34 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Did you remove the upper A arms at any point? Might be OK IF you did not, but I'd do it anyway. No on the upper and lower control arms.
[Re: Sammy]
#2930921
06/07/21 02:58 PM
06/07/21 02:58 PM
Posts: 4,696 On the parachute mount
n20mstr
if the Upper and Lower arms were left bolted to the car, you should be pretty close to where you were originally. Car should drive the same, doesnt hurt though to get an alignement.
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2930927
06/07/21 03:02 PM
06/07/21 03:02 PM
Posts: 2,524 PA
moparacer
PA
I would think the toe might need checked if anything....
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Sammy]
#2931026
06/07/21 07:01 PM
06/07/21 07:01 PM
Posts: 20,659 in a cattle trailer down by th...
Guitar Jones
Just curious if both upper and lower weren't touched, what could have changed? You left out a lot of important info, like is this a stock suspension, aftermarket, Mustang II, what car is this, etc., etc. You replaced the spindles? Where they the same and why? A lot could change depending on how worn the old parts were and if the new ones are the same. Seeing as how you changed the brake set up I'd bet they are not the same.
[Re: Guitar Jones]
#2931052
06/07/21 07:54 PM
06/07/21 07:54 PM
Sammy
Wind Gap,Pa.
Just curious if both upper and lower weren't touched, what could have changed? You left out a lot of important info, like is this a stock suspension, aftermarket, Mustang II, what car is this, etc., etc. You replaced the spindles? Where they the same and why? A lot could change depending on how worn the old parts were and if the new ones are the same. Seeing as how you changed the brake set up I'd bet they are not the same. Stock front-end. Somebody cut the threaded spindle to make it shorter. Then drilled a new hole for a cotterpin. New brakes would not work correctly. It was a hack job and I wanted it correct , so I bought NOS front spindles. All new MOOG ball j onto.
[Re: dvw]
#2931654
06/09/21 02:35 PM
06/09/21 02:35 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
Any time I replace ball joints, I check the alignment. Ball joints are not as precision as you would think. You can check the camber and toe yourself with simple tools. If they are good, the caster is probably good too. If they have changed, you need to reset it all.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2931800
06/09/21 09:26 PM
06/09/21 09:26 PM
Posts: 11,656 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
[quote=Hemi_Joel]Any time I replace ball joints, I check the alignment. Ball joints are not as precision as you would think. You can check the camber and toe yourself with simple tools. If they are good, the caster is probably good too. If they have changed, you need to reset it all. [/quote}
Had it been aligned before by someone who knows where a drag car should be? If yes, and I didn't have any of the adjustments loose, I might check that stuff in the shop, make an easy hit, just to see if it drives okay and the steering wheel is still straight.
If not, now would be a good time.
[Re: CMcAllister]
#2931879
06/10/21 08:14 AM
06/10/21 08:14 AM
Sammy
Wind Gap,Pa.
If not, now would be a good time. My dart was aligned properly with a drag race alignment prior to replacing all the new parts. It went straight as an arrow.
[Re: Sammy]
#2931999
06/10/21 02:21 PM
06/10/21 02:21 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I just replaced the front spindles,wheel bearing, front brakes from Wilwoods to Strange, upper and lower ball joints. Everything greased and new cotter pins in place. Car was straight as an arrow prior to the whole front-end being changed. Do I need a wheel alignment or do I send it? With the spindles being replaced you without doubt need an alignment.
[Re: NITROUSN]
#2932038
06/10/21 04:25 PM
06/10/21 04:25 PM
Sammy
Wind Gap,Pa.
I just replaced the front spindles,wheel bearing, front brakes from Wilwoods to Strange, upper and lower ball joints. Everything greased and new cotter pins in place. Car was straight as an arrow prior to the whole front-end being changed. Do I need a wheel alignment or do I send it? With the spindles being replaced you without doubt need an alignment. Why? Same exact spindles but just NOS.
[Re: Sammy]
#2932099
06/10/21 08:16 PM
06/10/21 08:16 PM
NITROUSN
I just replaced the front spindles,wheel bearing, front brakes from Wilwoods to Strange, upper and lower ball joints. Everything greased and new cotter pins in place. Car was straight as an arrow prior to the whole front-end being changed. Do I need a wheel alignment or do I send it? With the spindles being replaced you without doubt need an alignment. Why? Same exact spindles but just NOS. For one simple reason first. Any time a part is replaced you should do an alignment. Second you have no idea if the spindles were forged the same. Third you have no idea if your original spindles were 100 percent correct. The car was aligned off them. Plus a few more. So why ask. Crash it.
