Before I crash this car.. #2930888
06/07/21 01:30 PM
06/07/21 01:30 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I just replaced the front spindles,wheel bearing, front brakes from Wilwoods to Strange, upper and lower ball joints. Everything greased and new cotter pins in place.
Car was straight as an arrow prior to the whole front-end being changed.
Do I need a wheel alignment or do I send it?
Re: Before I crash this car.. [Re: Sammy] #2930904
06/07/21 01:55 PM
06/07/21 01:55 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Did you remove the upper A arms at any point? Might be OK IF you did not, but I'd do it anyway.
69 GTX 68 Road Runner
Re: Before I crash this car.. [Re: JERICOGTX] #2930915
06/07/21 02:34 PM
06/07/21 02:34 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
No on the upper and lower control arms.
Re: Before I crash this car.. [Re: Sammy] #2930921
06/07/21 02:58 PM
06/07/21 02:58 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
if the Upper and Lower arms were left bolted to the car, you should be pretty close to where you were originally. Car should drive the same, doesnt hurt though to get an alignement.
....BAD A$$ STREET CAR.....
Re: Before I crash this car.. [Re: n20mstr] #2930927
06/07/21 03:02 PM
06/07/21 03:02 PM
PA
moparacer Offline
moparacer  Offline
PA
I would think the toe might need checked if anything....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Before I crash this car.. [Re: moparacer] #2930965
06/07/21 04:33 PM
06/07/21 04:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have the front end checked out... is it worth you crashing
wave
Re: Before I crash this car.. [Re: MR_P_BODY] #2931012
06/07/21 06:23 PM
06/07/21 06:23 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Just curious if both upper and lower weren't touched, what could have changed?
Re: Before I crash this car.. [Re: Sammy] #2931026
06/07/21 07:01 PM
06/07/21 07:01 PM
Guitar Jones Offline
You left out a lot of important info, like is this a stock suspension, aftermarket, Mustang II, what car is this, etc., etc.
You replaced the spindles? Where they the same and why? A lot could change depending on how worn the old parts were and if the new ones are the same. Seeing as how you changed the brake set up I'd bet they are not the same.
Re: Before I crash this car.. [Re: Guitar Jones] #2931052
06/07/21 07:54 PM
06/07/21 07:54 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Stock front-end.
Somebody cut the threaded spindle to make it shorter.
Then drilled a new hole for a cotterpin.
New brakes would not work correctly. It was a hack job and I wanted it correct , so I bought NOS front spindles.
All new MOOG ball j onto.
Re: Before I crash this car.. [Re: Sammy] #2931060
06/07/21 08:13 PM
06/07/21 08:13 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
You spent a lot of money to fix/correct issues with the front end. Now you don’t want to spend the money for an alignment that cost many $60 to $70. shruggy makes no sense to me. Go get the dang thing aligned if not for you for the guy in the lane next to you.
Re: Before I crash this car.. [Re: Sammy] #2931078
06/07/21 08:51 PM
06/07/21 08:51 PM
I would have it check to make sue that the new spindles are not requiring a new alignment twocents scope
Re: Before I crash this car.. [Re: Cab_Burge] #2931091
06/07/21 09:29 PM
06/07/21 09:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You did all that and didn't replace upper and lower control arm bushings? Or strut rod bushings either? My bet is they could be worse than most of the stuff that was replaced.
Doug
Re: Before I crash this car.. [Re: dvw] #2931654
06/09/21 02:35 PM
06/09/21 02:35 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Any time I replace ball joints, I check the alignment. Ball joints are not as precision as you would think. You can check the camber and toe yourself with simple tools. If they are good, the caster is probably good too. If they have changed, you need to reset it all.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Before I crash this car.. [Re: Hemi_Joel] #2931800
06/09/21 09:26 PM
06/09/21 09:26 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
[quote=Hemi_Joel]Any time I replace ball joints, I check the alignment. Ball joints are not as precision as you would think. You can check the camber and toe yourself with simple tools. If they are good, the caster is probably good too. If they have changed, you need to reset it all. [/quote}
Had it been aligned before by someone who knows where a drag car should be? If yes, and I didn't have any of the adjustments loose, I might check that stuff in the shop, make an easy hit, just to see if it drives okay and the steering wheel is still straight.
If not, now would be a good time.
Re: Before I crash this car.. [Re: CMcAllister] #2931879
06/10/21 08:14 AM
06/10/21 08:14 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
My dart was aligned properly with a drag race alignment prior to replacing all the new parts.
It went straight as an arrow.
Re: Before I crash this car.. [Re: Sammy] #2931999
06/10/21 02:21 PM
06/10/21 02:21 PM
N
NITROUSN Offline
NITROUSN  Offline
N
With the spindles being replaced you without doubt need an alignment.
Re: Before I crash this car.. [Re: NITROUSN] #2932038
06/10/21 04:25 PM
06/10/21 04:25 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Why?
Same exact spindles but just NOS.
Re: Before I crash this car.. [Re: Sammy] #2932099
06/10/21 08:16 PM
06/10/21 08:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Why?
For one simple reason first. Any time a part is replaced you should do an alignment. Second you have no idea if the spindles were forged the same. Third you have no idea if your original spindles were 100 percent correct. The car was aligned off them. Plus a few more. So why ask. Crash it.
