Odd 727 tranny leak! #293058
04/19/09 05:40 PM
04/19/09 05:40 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Bought this '73 D-100 truck as a project last week. I was told that the tranny (727) had
a front seal leak, that it was fixed, and that it came back shortly afterwards. Okay says
I, some more fun work! Today I took a look for the first time. Now, thinking about the 727,
if the front seal were leaking, the only place it could come out is at the inspection cover
on the front of the bellhousing (which is integrated with the case).
But my inspection cover, and indeed the whole bottom of the bellhousing, is dry as a bone!!
The leak (only when it's running) is right over the crossover pipe for the exhaust, and
directly above it is the front of the tranny pan. And that area is wet! To me, this
is where it seems to be coming from as I watch it.
So my question is, does returning fluid flow over the inside of the front pan area
when the pump is running? The outside of the gasket looks pretty bad, so I'm hoping
all I have is a bad gasket and not a front seal leak.
Re: Odd 727 tranny leak! [Re: polkat] #293059
04/19/09 06:03 PM
04/19/09 06:03 PM
Az
Crizila Offline
Crizila  Offline
Az
While you have the trans pan off, lay it on a flat surface and check the area around the front of the trans pan. My wifes car leaked at that exact same spot and the pan rail ( gasket surface ) was not flat in that area. A hammer and a fresh gasket fixed the problem. Also check the dip stick tube area ( right front of the case )for leaks. It's close by.
Fastest 300
Re: Odd 727 tranny leak! [Re: Crizila] #293060
04/19/09 06:56 PM
04/19/09 06:56 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Check for a leak at the dipstick tube.
Re: Odd 727 tranny leak! [Re: polkat] #293061
04/19/09 06:57 PM
04/19/09 06:57 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
It's not coming out the vent is it? If the inside of the bell is all dry, probably not... Just a thought.
Re: Odd 727 tranny leak! [Re: polkat] #293062
04/19/09 07:06 PM
04/19/09 07:06 PM
Chesterfield, MIch
Cuda67 Offline
super street
Cuda67  Offline
super street
Chesterfield, MIch
Just another thought. When the front pump seal starts leaking, not only is the seal no good but neither is the front pump bushing. If you only relace the seal it will start leaking before to long.
Re: Odd 727 tranny leak! [Re: polkat] #293063
04/19/09 07:19 PM
04/19/09 07:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Before you go replacing parts at random, get a can of spray brake clean and clean the entire area, then take a flashlight and mirror to pinpoint the source of the leak.
If the leak is on the drivers side suspect one of the cooler lines or the shift shaft seal(s), if it's on the passenger side suspect the dipstick tube.
Re: Odd 727 tranny leak! [Re: John_Kunkel] #293064
04/19/09 07:26 PM
04/19/09 07:26 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Did clean it up. The leak appears to be on the passengers side at the front pan rail. The gasket at that point gets quite wet. The bottom of the bellhousing stays dry. I don't see how this could be a front seal!? Also, where the leak appears to be, the gasket has been squished out a bit. The leak is a fast drip, but doesn't appear to be under pressure. The filler tube (where it goes into the case)looks dry. The leak happens only with the engine running (either moving or stopped) and I was wondering if returning fluid might flow down that area on the inside. I will pull the pan tomorrow and check it out.
Re: Odd 727 tranny leak! [Re: polkat] #293065
04/19/09 07:34 PM
04/19/09 07:34 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Check the pan-rail ...it is probably warped or bent.
Re: Odd 727 tranny leak! [Re: John_Kunkel] #293066
04/19/09 10:10 PM
04/19/09 10:10 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
And will add that sometimes fluid leaks originate in one place, drip down to the pan gasket upper lip, then run to the lowest point and DRIP. making one think it's the PAN GASKET, Wrong!!! As John said, clean, clean, clean, then wait for the drip. Trace it back to it's origin.
The key is have the entire area clean first. A couple of other problem areas that can lead one to suspect a pan or gasket are, The low/reverse band oring Ugly solution , the Tailshaft bearing seal/gasket.
As said before clean it thoroughly, then look for the source. keep in mind the fluid does not go uphill. So once clean and dry, look for the source, maybe the pan gasket is wet but what is wet above it. Hope this makes sense
Tim
Re: Odd 727 tranny leak! [Re: TJP] #293067
04/19/09 10:36 PM
04/19/09 10:36 PM
Grand Prairie,Texas
Grand Prairie,Texas
replace the pan gasket with one of the new rubber metal rubber sandwich gaskets. They are reusable and won't crush.
Re: Odd 727 tranny leak! [Re: stumpy] #293068
04/19/09 11:11 PM
04/19/09 11:11 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Yep! Does make sense, but as I said (didn't I?) I've cleaned it, and above the pan was dry everywhere. But I'll clean it again!
Re: Odd 727 tranny leak! [Re: polkat] #293069
04/19/09 11:20 PM
04/19/09 11:20 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
How about the selector shaft seal?
Re: Odd 727 tranny leak! [Re: SomeCarGuy] #293070
04/19/09 11:33 PM
04/19/09 11:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Go to local Dodge Dealer parts counter... Ask for pan gasket for 95 dodge truck with V-10... Pay cashier... Take trick new pan gasket home...Install trick new pan gasket...End of story...
Re: Odd 727 tranny leak! [Re: polkat] #293071
04/21/09 10:57 AM
04/21/09 10:57 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I just want to say that I myself got stung by a leaky servo cover (brand x) just 2 weeks ago. In spite of knowing and following the advice I gave you I missed the source of the leak 3 times. SHAME ON ME!!!!
It was a very small leak that would take 3 days to drop anything on the floor. In my defense HAHA it was in an obscure area. After 3 days it would leak enough to run down the the top side of the pan gasket all the way to the front, then around the corner and then drip off the pan corner on the opposite side of the trans.
Most common areas on a TF are
Gear shift selector seal LF
Kickdown lever seal LF
Line fitting LF
Neutral safety switch or gasket L side
rear line fitting LR side
Speedo cable LR. Note: has an inner and outer seal
Low reverse oring seal, middle-rear of main case below tailshaft housing and above pan gasket.This one is notorious for selling pan gaskets
rear bearing access cover (under trans mount)
Dipstick tube RF
I normally use brake clean and paper towels to clean thoroughly until there is no fluid anywhere especially above the pan. Then check every so often with a clean paper towel. once the towel turns pink, follow it back to the source. Sounds eassy right???? That's how I missed the servo cover leak 3 times. ARRRGGGHHHH Shame on me!!!!
Good luck and let us know
Tim
Re: Odd 727 tranny leak! [Re: polkat] #293072
04/21/09 12:28 PM
04/21/09 12:28 PM
Northwood, Ohio
JJ300 Offline
JJ300  Offline
Northwood, Ohio
Sounds like a leak I had, turned out to be a cracked torque converter.
Re: Odd 727 tranny leak! [Re: TJP] #293073
04/21/09 02:19 PM
04/21/09 02:19 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
Line fitting LF
Dipstick tube RF
Tim
Most common,whether you know it or not,you just named every place a transmission could leak besides the front seal.
Re: Odd 727 tranny leak! [Re: I go fast] #293074
04/21/09 03:44 PM
04/21/09 03:44 PM
scratchnfotraction Offline
I just changed a pan gasket last week and the rubber squeezed out just a little on the corner and had a leak
R&R the pan dryed and installed anothe chep rubber gasket and used a 1/4 ratchet and by hand watching the gasket at the corners...no leak
often I will wash one with brake clean and dry with a air hose
throw a hand ful of baby powder around the suspected area and wait for the leak
the powder slows it down and marks the wet spot...
Re: Odd 727 tranny leak! [Re: I go fast] #293075
04/21/09 04:06 PM
04/21/09 04:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Yeah so you forgot that I also didn't mention the rear seal
The reason I didn't mention either was because the problem as stated appears to be pan related. The areas that I mentioned could make one think its a pan gasket. So there NAH NAH NAH NAH!!!
Re: Odd 727 tranny leak! [Re: scratchnfotraction] #293076
04/21/09 09:13 PM
04/21/09 09:13 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Okay, I pulled the pan and, placing a straight edge along the front pan edge, I found this at the right front corner (just where i thought the leak was. Sorry about the image from my ancient camera, but you can see where the pan dips (is bent) down near the end.
Could this be the source of my 'front seal' leak? Again, after through examination, I can see no other sources of leaks.
Re: Odd 727 tranny leak! [Re: polkat] #293077
04/21/09 09:29 PM
04/21/09 09:29 PM
IMO,yes that would be it
you could try a BFH on it or another pan
might want to get the newer pan gasket also,worth the 12-15 $ for it
if you do..FYI..it does not compress and it will strip the bolt hole if over torqued
usaly it will only pull half the threds out as the gasket is thicker
you can use a longer bolt it that hole or heli coil it DAMHIK
you can allways put a nice deep alum pan from summit on for 99$,
good luck
