Jeep connector pin extraction tool #2929924
06/03/21 10:09 PM
06/03/21 10:09 PM
Pikes Peak Country
TC@HP2 Offline OP
TC@HP2  Offline OP
Pikes Peak Country
Got a 2004 Grand Cherokee that needs some harness work. Rather than splice and solder, I'd like to replace individual wires between connectors, so I need a pin extraction tool(s). Problem is I can't find much info on the make of the connectors throughout the vehicle, nor what type of extraction tool would be required. First efforts are for the door and shifter harnesses. What do I need for those?
Re: Jeep connector pin extraction tool [Re: TC@HP2] #2930038
06/04/21 01:01 PM
06/04/21 01:01 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
These are the electrical pick that we used in the assembly plants when repinning connectors.
Miller 6680.
https://www.toolsource.com/terminal-tools-c-1321_408_520/electrical-terminal-pick-set-p-113923.html
Search Miller 6680 electrical pick for a source, pricing varies with each vendor.
