[quote=Tony21]
Just noticed that the front and back wheels and tires aren't identical. If you're talking about poorboy's truck, IIRC, it's on a Dakota frame and has 2 different style of Dak wheels.
Tim [/quote
My truck will be getting new tires shortly. I will be running the wheels on the front, I have the full set of 4. The current tires rear tires on those wheels that match the front do not hold air. The two tires on the rear set of wheels have really good tires on them, but their matching wheels also have bad tires. I have two sets of wheels, both with a pair of usable tires and a pair of bad tires (all of the tires are the same size). As is, it works right now to sort through the new ride shakedown runs. The truck was plated and insured yesterday, I put about 5 miles on it last evening. Hopefully tires are to come yet this month so I can have matching wheels (it bugs me more then you can imagine). Body work and paint to come towards fall, its too hot right now. Gene
