Re: 1975 Plymouth Trailduster: 4X4/lowrider or Drag Truck? [Re: topside] #2929806
06/03/21 03:55 PM
06/03/21 03:55 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Couple pre-runner style builds of those out there that look kinda cool.
https://www.offroadxtreme.com/news/walker-evans-tribute-dodge-ramcharger-prerunner/
Re: 1975 Plymouth Trailduster: 4X4/lowrider or Drag Truck? [Re: Neil] #2929822
06/03/21 04:55 PM
06/03/21 04:55 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
I’d like to have a stockish one for occasional towing.
China is the enemy.
Re: 1975 Plymouth Trailduster: 4X4/lowrider or Drag Truck? [Re: I_bleed_MOPAR] #2929878
06/03/21 08:13 PM
06/03/21 08:13 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Originally Posted by I_bleed_MOPAR
[quote=Tony21]Just noticed that the front and back wheels and tires aren't identical.
If you're talking about poorboy's truck, IIRC, it's on a Dakota frame and has 2 different style of Dak wheels. up
Tim [/quote
My truck will be getting new tires shortly. I will be running the wheels on the front, I have the full set of 4. The current tires rear tires on those wheels that match the front do not hold air. The two tires on the rear set of wheels have really good tires on them, but their matching wheels also have bad tires. I have two sets of wheels, both with a pair of usable tires and a pair of bad tires (all of the tires are the same size). As is, it works right now to sort through the new ride shakedown runs. The truck was plated and insured yesterday, I put about 5 miles on it last evening. Hopefully tires are to come yet this month so I can have matching wheels (it bugs me more then you can imagine). Body work and paint to come towards fall, its too hot right now. Gene
Re: 1975 Plymouth Trailduster: 4X4/lowrider or Drag Truck? [Re: migsBIG] #2931473
06/08/21 10:08 PM
06/08/21 10:08 PM
Souderton
Taylor Offline
Taylor  Offline
Souderton
Originally Posted by migsBIG
So I finally get it back and it’s much straighter and only minimal rust after being gone for 18 years. I wanted something fun, probably not practical and was thinking of converting it to a lowrider like I was originally intending. I don’t do off reading and I like in more city oriented area, so that makes more sense. Then since it’s smog exempt, big block and auto, why not build it for some track use? A nice cage, big beefie’s In the back and a decent engine with enough room up front for a super snail might be fun too. I got the idea from a Truckinin’ cover pic of a black Blazer I seen back in the day and though a Mopar would look even better. This won’t happen for years as I have 4 other mopars ahead of it, so I can take my time deciding the pro’s and cons of each one. What do you guys think?
Do the Drag truck like my Uncles old one
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/29559/4x4-to4x2.html#Post29559
Been awhile since that truck was done, the 511TFX saw the rode twice never hit the track, the new owner is the son, it now has a 426G3 and has gone a best of 8.99 no idea the MPH @ Cecil county back in 2019.
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi
2020 1320 Challenger....stock daily driver.
