Page 2 of 4 1 2 3 4
Re: Tim Banning vs Ray Barton [Re: mopar dave] #2929534
06/02/21 04:16 PM
06/02/21 04:16 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Originally Posted by mopar dave
Pete tells me 13:1 is the sweet spot for these Hemi’s. My plan was 12:1 and I’m now thinking just build it with 13:1 and live with it. I don’t mind mixing fuel as I do it now with my 12.5:1 511 wedge. Looking like CP will be the piston if a can find a shelf piston for this. Once I get the heads I can cc the chambers and intake to get a better idea on the compression and cam.
I doubt you are going to want to run anything less than straight 110 at 13 to 1
I had CP slugs in an old build. Sweet slugs. Very nice. Best did that motor, was very happy with it
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Tim Banning vs Ray Barton [Re: B3422W5] #2929631
06/02/21 08:49 PM
06/02/21 08:49 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Best (Chuck) built my 540" B1 motor16 yrs ago, (pre-Pete) and did a fantastic job. Best is more than capable for the HEMI.
My brother-n-law had FHO build his new all alum (KB block) 572" HEMI pump gasser last year for his '69 Super Bee streeter with a Passion 4-Speed. Its a complete animal when matted, and super tame under normal driving conditions. I drove the hell out of it this past Christmas. He raved about Tim's outstanding customer service, and more importantly how customer service was after the purchase.
"Any fool can know. The point is to understand"
- A. Einstein
Re: Tim Banning vs Ray Barton [Re: mopar dave] #2929646
06/02/21 09:09 PM
06/02/21 09:09 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
I think Al Aguire (sp) is selling a HEMI with many of the things you are looking for .... maybe not exactly what you want , but get what you need
Re: Tim Banning vs Ray Barton [Re: B3422W5] #2929696
06/03/21 08:41 AM
06/03/21 08:41 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Yeah, maybe i should stick with the 12:1. Don't want to get into the straight race fuel gig. I understand these Hemis are good on pump gas to 11.5:1, so shouldn't take much race fuel. I'm currently at 12.5:1 in the wedge and only use 4 or 5 gallons race fuel to 15 gallon cell. So, it looks like i'm on my way now with this Hemi project. Thanks guys
Re: Tim Banning vs Ray Barton [Re: mopar dave] #2929701
06/03/21 09:13 AM
06/03/21 09:13 AM
Lake Villa Il
INTMD8 Online content
INTMD8  Online Content
Lake Villa Il
Would you consider E85?
Re: Tim Banning vs Ray Barton [Re: mopar dave] #2929703
06/03/21 09:26 AM
06/03/21 09:26 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Told him I plan on using Molnar crank and rods and suggest a Callies rod instead. Not sure which Callies rod, so what are you guys using?
He probably means this one. https://www.callies.com/catalog/product/ultra-i-beam/? That's what I bought for my last build. (But I was trying to spend mo money.) Made in USA
2011 Drag Pak Challenger
Re: Tim Banning vs Ray Barton [Re: rickseeman] #2929733
06/03/21 11:13 AM
06/03/21 11:13 AM
an8sec70cuda Offline
I use a Callies Magnum crank, billet steel Oliver rods, and Diamond pistons. I went with better parts b/c I knew I'd end up spraying it eventually.
If it wasn't for the nitrous, I'd have probably used something like Molnar for the bottom end.
My thoughts on compression is do one or the other...meaning either use strictly pump gas or strictly race gas. Mixing fuels is a PITA and gets old quick. Keep it in the 11:1 range for pump gas or go 13:1 or better if you don't mind race fuel. twocents
FWIW...mine is making somewhere in the 850 hp range on pump gas w/ cnc ported MP heads (probably the closest thing to a stock heads in aluminum), 4.5" stroke, standard cam height and timing chain, etc. Pretty boring as far as big inch hemis go, but I can't argue w/ the results. It's been almost 142 mph in the 1/4 on motor only, on pump gas, and over 3800 lbs..
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Tim Banning vs Ray Barton [Re: INTMD8] #2929738
06/03/21 11:21 AM
06/03/21 11:21 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
At 12:1 a G2 aluminum hemi is just fine on 93 octane...Probably even 12.5:1.....
Re: Tim Banning vs Ray Barton [Re: Dragula] #2929770
06/03/21 01:15 PM
06/03/21 01:15 PM
Lake Villa Il
Lake Villa Il
He was considering 13-1 which is why I asked as it would work well for that.
Re: Tim Banning vs Ray Barton [Re: 10secGTX] #2929795
06/03/21 03:01 PM
06/03/21 03:01 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yeah what he said....Be happy to let you come get it wave
Re: Tim Banning vs Ray Barton [Re: Al_Alguire] #2929816
06/03/21 04:37 PM
06/03/21 04:37 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
What about Indy? They’re under new ownership & have moved to a larger facility.
China is the enemy.
Re: Tim Banning vs Ray Barton [Re: Al_Alguire] #2929828
06/03/21 05:09 PM
06/03/21 05:09 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for the offer Al, but i have to pass. I think its half the fun rounding up parts and putting it all together.
Re: Tim Banning vs Ray Barton [Re: mopar dave] #2929832
06/03/21 05:11 PM
06/03/21 05:11 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I had a Barton 572 hemi. It was 10.5-1. It made 804 on pump gas, no detonation, tire shredder. Don’t thing anymore is needed for the street.
Re: Tim Banning vs Ray Barton [Re: INTMD8] #2929834
06/03/21 05:24 PM
06/03/21 05:24 PM
Mt Morris Michigan
Mt Morris Michigan
That is a possibility, but i think its way more trouble than race fuel. Race fuel smells better.
Re: Tim Banning vs Ray Barton [Re: INTMD8] #2929837
06/03/21 05:35 PM
06/03/21 05:35 PM
Mt Morris Michigan
Mt Morris Michigan
I have time to decide, but it will be at least 12.5:1. Just got off the phone with Chuck, he suggested a Callie's crank as well. The compstar crank they like better than Molnar and the Compstar is less money than the Molnar as well. Sounds like a no brainer. Called Callies as well and they agree, the compstar rods and crank are good enough for what i'm doing. At this point it is also looking like i will need a CP custom piston as well. Adding up fast, but still will be way less money than Tim had me spending. Not a dig on him, just a fact.
Re: Tim Banning vs Ray Barton [Re: mopar dave] #2929885
06/03/21 08:29 PM
06/03/21 08:29 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I’m running 4.75 Callis crank with Oliver rods. Indy Max aluminum block, cnc Indy SR heads, 11:1 compression. It went 10.15@133 in 100 degree Arizona heat the first pass on the new engine and suspension on 91 octane and very conservative timing. Waiting for the Indian tribe that owns the land the track is on to lift the COVID mask mandate to go back. We’re already 100+, probably wait until the fall.
Re: Tim Banning vs Ray Barton [Re: gsmopar] #2929891
06/03/21 08:43 PM
06/03/21 08:43 PM
Mt Morris Michigan
Mt Morris Michigan
Nice, i think you will see a nice gain in the fall.
Re: Tim Banning vs Ray Barton [Re: mopar dave] #2929960
06/04/21 01:00 AM
06/04/21 01:00 AM
Chesterfield Twp. Mi.
John Burdine Offline
keep us up to date with this build.
Re: Tim Banning vs Ray Barton [Re: gsmopar] #2929965
06/04/21 02:33 AM
06/04/21 02:33 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
The track is on a reservation?
China is the enemy.
Re: Tim Banning vs Ray Barton [Re: John Burdine] #2929993
06/04/21 09:09 AM
06/04/21 09:09 AM
Mt Morris Michigan
Mt Morris Michigan
Yes, i will. Something else i have learned is the stage v heads have to be drilled for 1/2" head stud. Tim didn't mention that and the BM block has something smaller, not sure the size, but hope i can still use these heads on the BM block with the smaller stud. It's a constant learning curve with this Hemi stuff, but it is fun.
Page 2 of 4 1 2 3 4
