Re: Tim Banning vs Ray Barton
[Re: 1972CudaV21]
#2930016
06/04/21 10:41 AM
06/04/21 10:41 AM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
The track is on a reservation? Yes it is owned by the Gila River Indian tribe and is on Tribal lands.
[Re: gsmopar]
#2930057
06/04/21 02:27 PM
06/04/21 02:27 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Waiting for the Indian tribe that owns the land the track is on to lift the COVID mask mandate to go back. We’re already 100+, probably wait until the fall. Makes two of us! Limited track schedule and I don't want to tow to Tucson either! The other issue is FINDING and buying another enclosed trailer. I'm not going to pay the crazy prices people or businesses are asking. UGH!
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#2930093
06/04/21 04:50 PM
06/04/21 04:50 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Waiting for the Indian tribe that owns the land the track is on to lift the COVID mask mandate to go back. We’re already 100+, probably wait until the fall. Makes two of us! Limited track schedule and I don't want to tow to Tucson either! The other issue is FINDING and buying another enclosed trailer. I'm not going to pay the crazy prices people or businesses are asking. UGH! No kidding on the trailer! I almost drove to Waco last year to pick one up. Prices have gone nuts since then. Probably should have pulled the trigger.
[Re: John Burdine]
#2932359
06/11/21 09:00 PM
06/11/21 09:00 PM
Posts: 8,041 Mt Morris Michigan
mopar dave
Mt Morris Michigan
A little update. Tim has my heads almost ready to ship. Not able to download and send flow sheet, but they flow 442@.700 and 471@.850. Its looking like the cam will be just under .750 lift, maybe .725 after lash. Used Manley Nextec springs set up at 1.950. Looks like should be 225# on seat and .610@.730 lift. Once i get them, i can cc chambers and send that info off to Best Machine and get the pistons ordered.
[Re: mopar dave]
#2932407
06/12/21 06:05 AM
06/12/21 06:05 AM
Posts: 3,190 Md.
carnut68
Md.
Impressive looking . How much $ will you have in them,if you don't mind me asking. I know I had about 2800 in my EZ heads.
America First!
[Re: mopar dave]
#2932423
06/12/21 08:50 AM
06/12/21 08:50 AM
Posts: 114 NW Indiana
powertrip
NW Indiana
Whose rocker gear will you be using? And what compression ratio have you decided on?
Those are some impressive heads.
[Re: mopar dave]
#2932458
06/12/21 11:40 AM
06/12/21 11:40 AM
Superfreak
Superfreak
I have the FHO Stage V custom head that is o-ringed on the intake side but same flow numbers as shown above. $6500 canadian pesos. Also went with the RB T&D's for another $5000 canadian pesos. Definitely not cheap. What ever the reason/s for you building a hemi, they are your reason/s so don't worry about what others think or babble on about a wedge being cheaper. I am building a roots blown hemi because I have always dreamed of doing so and I don't give a sh!t what others think. As soon as the boarder opens up I will be sending my dominators to a vendor I found in the states to have them converted to E85. Have at her and have fun doing it.
[Re: mopar dave]
#2932514
06/12/21 02:34 PM
06/12/21 02:34 PM
Posts: 3,190 Md.
carnut68
Md.
Waiting on the call from Tim for the final bill, but will be about twice that. The real eye opened is the rocker gear. Looks like another $3500+. Hemi's are very expensive, but i have the money right now to do this and i'm pulling the trigger before i retire. I don't blame you on doing what you want while you can. I put a 511 rb rotating assembly together last spring of course it's on hold, because of the cam shortages, but I'm glad I didn't wait. Good luck with the build.
America First!
[Re: mopar dave]
#2933083
06/14/21 09:10 AM
06/14/21 09:10 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
Great numbers! I have about 2800 into my victor Jrs.
Rich H.
Esse Quam Videri
[Re: dthemi]
#2933354
06/14/21 09:15 PM
06/14/21 09:15 PM
Posts: 3,077 Michigan
A727Tflite
Here's one I just finished and dynoed Thursday.
MP water block MP aluminum hemi heads Independent shaft rockers 4.3 x 4.15 bore stroke Tunnel ram 2 E85 wj dominators Standard cam tunnel with jesel tappets.. Nothing fancy anywhere. Just really good head, manifold, and carb work. A bigger tunnel would have made a few more stable rpm. but zero need for a 60. 54mm would have been fine. Point being, it doesn't take a lot of trick stuff to make decent power with a hemi.
Also Ray would win the contest if there was one between him and Tim. No offense intended towards him, just a whole different level of know how. How much lift and duration? What lifter type?
