Duster cam #2929055
06/01/21 04:14 AM
06/01/21 04:14 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Got myself a 71 Duster a couple of years ago, seller had no clue of engine internals or nothing else but I got a good deal and bought it. Haven't had time for it until now.
340", Eddie heads, Torker intake, expensive red dp carb, newer crap MP distributor, Hooker Comp headers... that's what you can see.
Fiber glass hood and bumpers, subframe connectors, full interior, drag radials... Will see mostly short trips and some visits to the 1/8-mile. Stalls around 3,000. Would guess 3.91 gearing. Manual valve body.
Started it and it run. Drove it home, 7 miles. No noises but run like a pig.
Did a compression test: 15-154 psi except for cyl 1 with zero. Stamped steel rockers. Exhaust pushrod stamped its own hole in a rocker, his brother intake had an s-shape so I pulled the engine and then the head. Looks all good otherwise. No damage on head, cyl walls look good. Pistons all the way up to deck.
Single springs seems a little strange with that high lift cam. Will check pressure open and closed.
Got a set of 273" ductile iron rockers from a friend yesterday. Will check lift and duration on cam tonight. Will also pull pan and see if there's something there I don't want to see there.
Have no experience of 340's so looking for advice. I guess to much lift and high revs for OEM rockers and 273" rockers will do?
What duration, lift and LS would work best with the combo above?
Thanks!
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Duster cam [Re: HP2] #2929064
06/01/21 06:44 AM
06/01/21 06:44 AM
Northern Bavaria / Germany
MichaelF Offline
MichaelF  Offline
the eddies in stock form are somewhat limited lift-wise....as far as i know .525". Consider this when getting a cam, check out the heads. The mechanical rockers will do the trick if in good shape.....i´d consider a solid flat tappet around 230 - 240° @ .050" / 108° LSA for your usage.
Michael
Re: Duster cam [Re: MichaelF] #2929182
06/01/21 02:29 PM
06/01/21 02:29 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Michael
That's good info on the lift limit, I will check that, thanks.
Measured the cam and it has only around 217° and .507" on intake. It would be better in my Warlock. I need a bit more cam...
71 Duster 340
Re: Duster cam [Re: HP2] #2929258
06/01/21 06:10 PM
06/01/21 06:10 PM
Need or want? work grin
Re: Duster cam [Re: Cab_Burge] #2929376
06/02/21 04:58 AM
06/02/21 04:58 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
As I stated before, I have never built a 340 before. But to optimize that little screamer in a Duster combo I think it needs more duration. Or?
71 Duster 340
