Treadwear rating
#2928928
05/31/21 03:48 PM
05/31/21 03:48 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
Hello fellow Moparians
I need to know a.s.a.p.the treadwear rating for Mickey Thompson Sportsman S/R tires. I have been searching the web without any luck.
Please respond if you know it or can cite a website with that info.
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Treadwear rating
[Re: BadMoonRacer]
#2928941
05/31/21 04:24 PM
05/31/21 04:24 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
Well, I guess nobody knows the answer since the manufacturer does not have that info. This is from Jeg´s website:
UTQG Tread Wear Rating N/A Temperature Rating N/A Traction Rating N/A How come they won´t divulge this necessary info??
[Re: BadMoonRacer]
#2929070
06/01/21 07:45 AM
06/01/21 07:45 AM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
I would guess it because they are "Performance" tires and therefore wont put a wear rating (guarantee) on them.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: BadMoonRacer]
#2929086
06/01/21 09:26 AM
06/01/21 09:26 AM
Posts: 22,696 Bitopia
jcc
Bitopia
UTQG Tread Wear Rating N/A Temperature Rating N/A Traction Rating N/A How come they won´t divulge this necessary info?? I believe its required by law to at least be on the new tire sticker, how you force the issue before purchase, is beyond me. Only applicable exception I can think of is if tire is clearly marked "Race only,"" or "not foe use on public roads". Its not an end all, be all number anyway. kinda like trying to judge how fast a car is by only asking its weight.
[Re: plycuda]
#2929326
06/01/21 09:24 PM
06/01/21 09:24 PM
Posts: 12,150 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
One important note on this; the wear ratings are only manufacturer specific. They only compare to other tires in that particular manufacturer's line. The ratings have no relevance to ratings on other manufacturer's tires. Of course, the 000 wear rating on my drag radials is not a real point of comparison anyway.
Master, again and still
[Re: plycuda]
#2929587
06/02/21 06:51 PM
06/02/21 06:51 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
Thank you for this info plycuda, I wonder what the difference is between the S/R and S/T Sportmans.
[Re: BadMoonRacer]
#2929654
06/02/21 09:43 PM
06/02/21 09:43 PM
Posts: 4,684 Wichita
GY3
Wichita
Thank you for this info plycuda, I wonder what the difference is between the S/R and S/T Sportmans. There is a huge difference in the compound of the S/R and S/T. My 275/60/15 S/T's are like driving on ice.
[Re: plycuda]
#2930120
06/04/21 07:29 PM
06/04/21 07:29 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
We are running in a class that says "Only true radial tires allowed, Drag radials and soft compound tires not allowed." One competitor showed up on M/T E.T: Street and another on R/T Sportsmans. A debate ensued if the R/T´s would qualify as soft compound, the E.T. were definately illegal. The wisdom I have picked up on the www is that "true" radials have a treadwear of 400 and higher. The R/T´s do not give any info about its treadwear. You can see a video of these races here: https://www.youtube.com/watch?v=egkLVtFVWZYMy Charger had a bad day; spinning the wheels almost half track. There is another race on June 19th. I plan to do better then Thank you for your interest, Ragnar in iceland
