4x4 truck trans #2928096
05/29/21 01:18 PM
05/29/21 01:18 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Would the aod 4x4 trans fit in a 79 truck (redoing the trans x member?)? I’m guessing 83-92 type trans?
Re: 4x4 truck trans [Re: cudaman1969] #2928183
05/29/21 03:56 PM
05/29/21 03:56 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
It depends what transfercase combination you use. I am using a 47rh to an Np 205 and there is no support on the tran/t-case adapter so I will have to make one to the existing cross member on my 78.
Re: 4x4 truck trans [Re: Uberpube] #2928230
05/29/21 05:17 PM
05/29/21 05:17 PM
fredericksburg,va
fredericksburg,va
Should have said an auto trans. Looked at a friends 79 and it looks like a cast iron hookup to the regular case, but wondering about a newer type (with the overdrive part) if can’t find the 79 one.
Re: 4x4 truck trans [Re: cudaman1969] #2928324
05/29/21 09:41 PM
05/29/21 09:41 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Up through 1979 it was a 203 . 80 and newer was a 208 and its variants.
Re: 4x4 truck trans [Re: NITROUSN] #2928346
05/29/21 11:09 PM
05/29/21 11:09 PM
fredericksburg,va
fredericksburg,va
When was the first year for OD?
Re: 4x4 truck trans [Re: cudaman1969] #2928386
05/30/21 06:39 AM
05/30/21 06:39 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
88 i think. Most trucks will have the NP 208. Around 91 the NP 241 become available. The NP 205 was also available in high gvw trucks.
Either way, it's a very different mounting arrangement than the NP 203 cases used. Grab the od transmission, case and crossmember from the same truck
Angry white pureblood male
Re: 4x4 truck trans [Re: ruderunner] #2928406
05/30/21 08:44 AM
05/30/21 08:44 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
89 was the first year for OD, If you go with an overdrive trans it will push back the transfer case so both cross members and drive shafts will be needed.
Re: 4x4 truck trans [Re: Moparite] #2928456
05/30/21 11:10 AM
05/30/21 11:10 AM
fredericksburg,va
fredericksburg,va
Thanks to both answers, will have to shorten the back shaft since this is a short step side, get crossmember mounts too.
Re: 4x4 truck trans [Re: cudaman1969] #2928684
05/30/21 09:29 PM
05/30/21 09:29 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
With a short rear driveshaft, you are really going to have to watch the height difference between the rear axle and the back end of the transfercase. You will run out of U-joint movement pretty quickly with a short DS.
Re: 4x4 truck trans [Re: poorboy] #2928948
05/31/21 04:42 PM
05/31/21 04:42 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
On my ramcharger build, the rear yoke ended up within 1/4" of where it was before swap. Went from r big block 727/np203 to 47rh/np205.
