hydraulic cam break in mule block #2925575
05/22/21 04:49 PM
05/22/21 04:49 PM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
Anyone attempted using a mule block set up for cam break in?
Is anyone offering this type of service?
Thinking of setting up an electric motor with a rheostat to spin the cam, plum the block with external electric pump to oil the cam journals, spray bar for the lobes, and run lines to the rocker arm shafts.
Interested in you guys thoughts on this.
Re: hydraulic cam break in mule block [Re: mgoblue9798] #2925582
05/22/21 05:04 PM
05/22/21 05:04 PM
Kirkland, Washington
Pacnorthcuda Offline
Every block is different, so the position of each lifter to its lobe will be slightly different when the assembly is transferred to the engine.
Re: hydraulic cam break in mule block [Re: Pacnorthcuda] #2925600
05/22/21 05:42 PM
05/22/21 05:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
When you’re really really really worried about the cam going flat........ you pony up for the roller.
Re: hydraulic cam break in mule block [Re: Pacnorthcuda] #2925601
05/22/21 05:49 PM
05/22/21 05:49 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I've lost two engines that the cam and lifters survived in (solid lifter). I used the cam and lifters in the replacement engines and lost both cams in short order. My conclusion is that lifters don't like being swapped into different engines after being broken in.
Brian
Re: hydraulic cam break in mule block [Re: fast68plymouth] #2925602
05/22/21 05:50 PM
05/22/21 05:50 PM
...and pray it doesn’t come apart! LOL
Re: hydraulic cam break in mule block [Re: Pacnorthcuda] #2925612
05/22/21 06:34 PM
05/22/21 06:34 PM
Atlanta, GA
Atlanta, GA
Thanks to everyone for the input. If I go any further with this sounds like I need to find a way to use the same block the cam will run in to do it.
Re: hydraulic cam break in mule block [Re: mgoblue9798] #2926578
05/25/21 05:26 PM
05/25/21 05:26 PM
London, England
Gavin Offline
Gavin  Offline
London, England
These Ford guys don't seem to think block to block variation is an issue....
Cam Research
Re: hydraulic cam break in mule block [Re: Pacnorthcuda] #2926594
05/25/21 06:07 PM
05/25/21 06:07 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Bingo. Jim Dowel (Racer Brown) and I had this very discussion and he recommended to not use a broken in cam in another block. It I was in a spot and had to try a cam I successfully ran before in a different block. I did it’s job and gave me time but it did wipe out the cam and lifters. He went on to say factory specs are the issue
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: hydraulic cam break in mule block [Re: Gavin] #2926624
05/25/21 08:03 PM
05/25/21 08:03 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Cam Research
I know a racer that runs an FE 427 in stock classes and he has used this service with success (didn't eat the cam in short order) shruggy Maybe Ford blocks are different and the lifter bores are machined more accurately but they have been doing this service for quite a while now.
Gus beer
64 Plymouth Savoy
Dana 60
Re: hydraulic cam break in mule block [Re: fourgearsavoy] #2926654
05/25/21 09:13 PM
05/25/21 09:13 PM
PA.
"Little"John
"Little"John
PA.
Cam Research
Gus beer
You are always going to get a split percentage both ways. Heck I changed 4 lifters in a 360 I built for my van in an ocean city parking garage with zero issues. I always kept a spare box of solid lifters in my race car trailer for 3 day race weekends.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
