Re: Help me Guess my E.T. ?
[Re: wkroncke17]
#2979522
10/29/21 09:44 AM
10/29/21 09:44 AM
Posts: 95 Cumming Georgia
cspracer
Cumming Georgia
Did you ever make it to the track? I am curious to see how the car actually did. I was guessing 10.90 myself, but figured the first few times out you would be in the low 11's.
1968 - 383 Roadrunner 4 speed street car, Dad bought new 1970 - 440 Roadrunner drag footbrake car 6.99 1/8th 2016 - Hemi RAM 1500 - Hauls all the toys North Georgia / Central NC
[Re: cspracer]
#2981419
11/03/21 05:13 PM
11/03/21 05:13 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
You should be able to 60 foot in the 1.40s no problem.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 65signet]
#2981737
11/04/21 04:58 PM
11/04/21 04:58 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Years ago when I ran a 408 stroker, I tested carbs. I don't remember the exact results but went from a 750 to 850 to 950HP and ran the fasted with the 950HP.
Nice car! It would love FI on it and then you can play around with data logging and really get a nice tune on it!
[Re: rb446]
#3085615
10/12/22 10:30 PM
10/12/22 10:30 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
According to my calcs 500hp@3500lbs, 4.30 gear and 28" tyre?, your slip would look something like this on a good hit>
Power to Weight Ratio: 0.14 : 1 (HP per 1 Pound Weight) 60 Foot E.T. : 1.55 1/8 Mile E.T. : 7.03 1/8 Mile Trap Speed :96.68 1/4 Mile E.T. : 11.14 1/4 Mile Trap Speed :120 1/4 Mile Trap RPM :6,210rpm+slip of course things vary on the day. and just to add another opinion Finally made it to the track! RB you we’re almost dead on! Right off the trailer I was impressed but it definitely has more in it. PTC converter flash stalls at just over 4000. Gear is too tall, I lifted before the line, it was at 6500, didn’t want to push it. Timing is at 14 initial, 36 total, running 93 pump gas. I tell ya, what a blast. Let me know your thoughts guys! And thank you for all of the previous advice and help here! Wally.
[Re: wkroncke17]
#3085636
10/13/22 12:43 AM
10/13/22 12:43 AM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
Congratulations Wally! Glad to see you finally got it out.
[Re: FastmOp]
#3085682
10/13/22 07:57 AM
10/13/22 07:57 AM
Posts: 570 UK
rb446
UK
Nice, here's what it could with those 60's at WOT to the traps> 60 Foot E.T. : 1.49 Seconds 1/8 Mile E.T. : 6.75 Seconds 1/8 Mile Trap Speed :100.70MPH 1/4 Mile E.T. : 10.70Seconds 1/4 Mile Trap Speed :123>125 MPH
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: wkroncke17]
#3085712
10/13/22 09:57 AM
10/13/22 09:57 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Nice runs and great pic!
Were you letting off early? (edit, nevermind, I see you did)
[Re: wkroncke17]
#3085851
10/13/22 10:12 PM
10/13/22 10:12 PM
Posts: 3,087 Michigan
A727Tflite
Thanks all! I’m thinking of a 4:10, or if I wanted to be a bit conservative a 3:91. My question is will it hurt the 60’ times much? I know a few have said more carb, more converter but the car is so very streetable right now I’m not sure I want to change too much? If it just touched the 10’s, you guys will probably hear me holler from Great Lakes Dragaway all the way to California! Again, thanks everyone! See if you can borrow a GoPro and capture rear tire slip (if any). You may pick up by reducing starting line ratio if spinning now. Was the track typical for traction? Plus you said you stopped short of the stripe. Not sure what impact that had on performance.
[Re: A727Tflite]
#3085889
10/14/22 06:57 AM
10/14/22 06:57 AM
Posts: 570 UK
rb446
UK
We got a guy here with almost the same set up as you, Demon,all steel +glass bonnet, street/strip car SSsprings,3.91's, 10x28 Bias, Hughes 3500 verter, prob under 10:1? Stock J heads 2.02/1.60 Mild 340/416, mild hyd. .474/495" TR with 2 x 650DP's.Shifts around 5600, traps around 6k.makes around 420fwhp here's a shot of his best run, has been 1.55 60 at the same ET. Its very soft on the hit not like yours. I would keep the gears and put a taller tyre on it, 4.10's would make around 200rpm difference in the traps, I would also at least try a bigger carb. I went 1.8 10ths quicker on my hyd. cammed 340 street/strip Cuda with a sorted 850DP over the 750DP that it came with. Just for a bit more info.
