Several things affect the valve float RPM, the tach, the amount of lifter preload, the lifter quality and the valve springs
i race a 1970 426 Cuda in NHRA stock for 2 1/2 years back in the early to mid 1970s, I had help a couple race a 1968 or 1969 hemi GTX the year before and the valve spring pressures where almost the same on those two motors, we would shift both of them right at 7000 RPM. The GTX had a Sun electric tach, I had a expensive electric Auto Meter tach in the Cuda which read 6200 RPM when it would nose over hard, I ended up adding a Jones Motorola mechanical tach in 1975 and found out that the Autometer read right at 1000 RPM less above 5000 RPM than the mechanical tach did so I threw it away. I saw the same thing later on another SB car I helped on, the electric tach read low in comparison to a tach drive tach above 4000 RPM
As far as your deal shift it when it quits pulling hard, don't wait for it to start popping and backfiring before shifting
