Thank you for posting pics!
I was planning on using a set of these but went Isky because of the /.180 offset vs. .210 offset that BAM offers. I know .030 is nothing to get excited about but when you have less than .450 to play with and the 900lb over the nose valve springs less offset would be better. If I ever build a "real" engine I might try them out. DLC and CrN coatings are truly amazing, especially when it comes to Ti valves and these steel on steel roller lifters.
