Tires cracking between tread(newish tires) #2924357
05/19/21 12:26 PM
05/19/21 12:26 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
2016 Dart purchased on Oct 31st 2017 for the wife. In October 2018, my wife hit a pothole and tore open the sidewall of one of the front tires. Since the original tires still had a lot of tread left, I replaced 2 instead of 4.(I replaced the other two in March of last year...the car is now my daily driver)
A few weeks ago I removed the snow tires I had on the car and installed the summer wheels/tires. That's when I noticed that both tires that were purchased in October 2018 are cracked just inside of the outer tread row. They are cracked all the way around the tire. There are no other cracks in between the other treads or on the sidewall. On May 8th, I drove to the tire dealer who installed the tires so they could look at them. The salesman took pictures of the cracks and said he would sent them to his rep. A week ago I still hadn't heard from them so I gave them a call. The salesman said that his rep sent the pictures to the manufacture so the engineers could make the determination on whether the tires were safe or need to be replaced.
The tire store called me this morning and said they still haven't heard anything back from the manufacture. He offered to replace the two tires for what I paid in 2018.(the tires are now more expensive then they were back then) So, what would you do? Just pay to replace them or wait and see what the manufacture says? The tires have been in service for only 2-1/2 years. The DOT date says they were made in Feb of 2018. It looks like I have 50K miles on them but the tread is still showing half.(about 1/8" above the wear indicators)
Re: Tires cracking between tread(newish tires) [Re: burdar] #2924412
05/19/21 01:34 PM
05/19/21 01:34 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
50,000 miles is pretty good if you are only at half-way on these tires. What kind are they?
Your dealer should give you prorating on those tires to a new set of the same tire. twocents
Since the dealer is trying to settle, it sounds like the Manufacture is trying to get out of the picture. That is what they use their dealers for. twocents
Mo' Farts
Moderated by "tbagger".
Re: Tires cracking between tread(newish tires) [Re: Grizzly] #2924414
05/19/21 01:51 PM
05/19/21 01:51 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
50k is a little heavy on their part. The car has 50k more miles on it then it did when the tires were installed but they sat all winter when the snow tires were on. They have maybe 43K miles which is still good though.
I didn't want to start a cheap tire/ tire brand debate so I purposely didn't list the brand. They are not a super cheap off brand tire. They are a name brand.
Re: Tires cracking between tread(newish tires) [Re: burdar] #2924420
05/19/21 02:05 PM
05/19/21 02:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The cracking would bother me, and I'd replace them.
I would think it's a mfg defect, especially if the tires spend half the year indoors when you're running winter tires.
If I was planning a trip, or drove highways with the car, replace now, save the old ones, press for warranty reimbursement.
If the car's only used low speeds, you might wait, but if one hatches they'll likely blame a road hazard.
It's never been a perfect world, and [censored] doth happen, but we're currently in the Age Of Mediocrity, whether its parts or services.
Sorry it's reeled you in.
Re: Tires cracking between tread(newish tires) [Re: topside] #2924426
05/19/21 02:09 PM
05/19/21 02:09 PM
PA
70Duster Offline
70Duster  Offline
PA
Replace with a different brand from a different tire store
Re: Tires cracking between tread(newish tires) [Re: 70Duster] #2924521
05/19/21 05:24 PM
05/19/21 05:24 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
The car my wife drives has 72,000 miles on it since 2008 and is on the 4th set due to cracking safety is 1st.
And that comes from a guy who used to have high HP and 4 wheel drums when I was young and not as smart.
The ones that came on it new did not wear well. Nor did the ones that replaced them but road damage killed one. so one was replaced by a road hazard warranty and the other 3 prorated. 3rd set cracked bad with, almost no miles so paid for 4th set.
4th set is a cheap BFG Touring with rim saver that has been the best so far.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Tires cracking between tread(newish tires) [Re: 340SIX] #2924612
05/19/21 08:31 PM
05/19/21 08:31 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I'm sure this is going to start a schitt show, but tire manufacturers have stated that a radial tires life span is no longer than 7 years from DATE OF MANUFACTURE, not date of install. My inlaws have a 2014 f150 with the original pirellis it came with, the truck has 60k miles on it with plenty of tread, and the entire circumference on all 4 tires, between all the treads are cracked. Driving around on broken ass tires will put you, your loved ones, and innocent people at risk. Replace the tires.
Re: Tires cracking between tread(newish tires) [Re: 70Duster] #2924623
05/19/21 08:44 PM
05/19/21 08:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree and will add the 50K on a set of tires IMO is time for replacing.
Re: Tires cracking between tread(newish tires) [Re: TJP] #2924625
05/19/21 08:46 PM
05/19/21 08:46 PM
Land of 10,000 Lakes
44D6PAKCUDA Online content
44D6PAKCUDA  Online Content
Most major tire brand warranty their tires for 6 years for weather cracking,on a pro-rated basis.At least I know Goodyear does
Re: Tires cracking between tread(newish tires) [Re: burdar] #2924644
05/19/21 09:24 PM
05/19/21 09:24 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
That's still exceptional. You could potentially get 75k out of them which is fantastic for a car tire.
So what exactly does the tire shop think of the cracking? Are they insisting they need to be replaced? If so, throw the ball in their court and demand prorating. If not, tell 'em to put it in writing on an inspection.
Mo' Farts
Re: Tires cracking between tread(newish tires) [Re: Grizzly] #2924673
05/19/21 10:11 PM
05/19/21 10:11 PM
5thAve Offline
5thAve  Offline
Are they thick cracks or hairline ones?
I don't put a lot of mileage on my cars so I usually end up replacing tires anyway because of age and cracks but I've never gotten the rated mileage out of tires.
Cracks of any type seem to becoming the norm for a lot of rubber stuff.
Re: Tires cracking between tread(newish tires) [Re: 5thAve] #2924734
05/20/21 07:32 AM
05/20/21 07:32 AM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
Tires today are just not made well. I play around in old Honda Mini-trails as well as cars. I have a couple of Hondas with the original tires on still from 1970. Rubber still looks great. No cracking, no checking, etc. Other bikes with 5 year old 'new' tires and they are garbage. Face it, like most all consumer items, the stuff being made today is not going to hold up over time. Kind of like the garbage shingles they sell for your house...
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Tires cracking between tread(newish tires) [Re: oldjonny] #2924747
05/20/21 08:57 AM
05/20/21 08:57 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Quote
These are only 3 years old from the date of manufacture. Tire manufactures also say that cracks like I'm showing are SAFE as long as they don't extend down to the chords.(but how are you going to make that determination with just a quick glance or a picture) To be clear, I'm not asking if these are safe to drive on. I WILL have them replaced. I was just wondering if most on here would wait to get some kind of answer from the manufacture or just pay for new tires themselves.
Here is a quick pic I just took with the cell phone. You get the idea...
Re: Tires cracking between tread(newish tires) [Re: burdar] #2924749
05/20/21 09:05 AM
05/20/21 09:05 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Next time don't buy Goodyear. As to the cracks, looking at your picture I'm not sure I would be concerned. They look like surface cracks that aren't that deep. At this point I'd keep driving them but I'd keep a close eye on them.
Re: Tires cracking between tread(newish tires) [Re: 6PakBee] #2924759
05/20/21 09:30 AM
05/20/21 09:30 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
They are NOT Goodyear tires.
We put a fair amount of miles on our cars so the age thing hasn't really been an issue. The tire tread is usually worn out long before they get close to 7 years old. We put 82K on the Dart in 3.5 years. I keep an eye on the tread but the age is in the back of my mind. The tread wear and age of these isn't something that would of had me concerned.
Re: Tires cracking between tread(newish tires) [Re: burdar] #2924769
05/20/21 09:43 AM
05/20/21 09:43 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Typical on Michelin tires (not saying that's what you have). My first experience with Michelin was the '94 Chevy CC dually I bought new. When it burned up in '98 it had about 40k miles on it with at least half the tread left. Had cracks about the same as your picture. Fast-forward to last year when I bought a vehicle with Michelins made in 2017 (tires, not vehicle). Same cracks. shruggy
As to running them or replacing them, I think that falls into the wha- makes-you-feel-better category. I personally wouldn't hesitate to drive on them but that is me.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Tires cracking between tread(newish tires) [Re: 5thAve] #2924792
05/20/21 10:49 AM
05/20/21 10:49 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree 100%. I tell customers that I will not warranty any rubber suspension bushings regardless of brand. I have seen many come back through the shop 4-5 years after install cracking or splitting.
I had a customer bring his car in a few years back. I called him and said your strut rod bushings need replacing. He said you just replaced those 3 years ago. OK, So I pull up the records and it states "Installed customer supplied front end kit" wink He said leave it for now.
Rare parts, PST / Kanter may be better as they do offer life time warranty's but not on the labor. And then getting the replacement is almost as much hassle or more than changing the part.
It Amazes me that the factory stuff went decades or 80-100K and the current offering can't make it 5K or 5 years. Seems like we've forgotten how to make rubber down . Hope this doesn't make it over to the condom Mfr's, LOL beer
Re: Tires cracking between tread(newish tires) [Re: 70Duster] #2924927
05/20/21 04:23 PM
05/20/21 04:23 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Yeah - I was going to say - I would NOT run that brand anymore!
Re: Tires cracking between tread(newish tires) [Re: Sunroofcuda] #2924931
05/20/21 04:34 PM
05/20/21 04:34 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I bet they are michilins, seen a ton of em do it very young age, on the other hand I never saw any come apart...
Re: Tires cracking between tread(newish tires) [Re: HotRodDave] #2924976
05/20/21 07:02 PM
05/20/21 07:02 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
In Pennsylvania, for your yearly inspection. You aren't allowed any cracks in the tires. They would fail at my shop.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
