Line Boring #2924303
05/19/21 11:31 AM
05/19/21 11:31 AM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
I have discovered that the line boring services is getting extremely hard to come by in North Texas. I have called just about every single machine shop in the North Texas region to get my customers 383 line bored with the new caps from 440 Source. No one hardly does it anymore, and if they do, it's only for Chevrolet engines. I found only one shop in Texas so far, Faerman Racing Engines in Houston. Has anyone in the Houston area ever dealt with them? Having to drive 3.5 hours to get this service done and they are 10 weeks out in getting it done. If anyone in the North Texas area has any contacts for North Texas that do line boring please let me know.
Darren
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Line Boring [Re: ChrgrCuda] #2924310
05/19/21 11:39 AM
05/19/21 11:39 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Did you try Wayne Calvert? It says they do the four bolt main cap installation and line honing.
https://www.waynecalvertengines.com/services
Floyd Lippencott IV
Re: Line Boring [Re: mr_340] #2924334
05/19/21 12:02 PM
05/19/21 12:02 PM
Texas, USA
Texas, USA
Yes sir I did. One of the first people I called as I grew up not far from there and Wayne Calvert was the machine shop of choice at one time. Unfortunately they don't provide this service anymore.
Re: Line Boring [Re: ChrgrCuda] #2924365
05/19/21 12:32 PM
05/19/21 12:32 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
A shop that only does line boring for Chevrolets? As my machinist said 20+ years ago, when I asked him if he worked on Mopars..."It's a F*#%ing chunk of iron. It doesn't know what it is. Square is square, and a round hole is just that".
69 GTX 68 Road Runner
Re: Line Boring [Re: JERICOGTX] #2924379
05/19/21 12:46 PM
05/19/21 12:46 PM
Texas, USA
Texas, USA
I would agree with you, however I think it may be a little more involved then that in regards to setting up the machine with the appropriate and required tooling for different OEM's. Regardless, that's what I keep getting back.
Re: Line Boring [Re: ChrgrCuda] #2924417
05/19/21 02:00 PM
05/19/21 02:00 PM
Ohio
jlatessa Online content
jlatessa  Online Content
Ohio
Not trying to be a smart a$$, but shouldn't the machining
be called align boring?
Joe
Re: Line Boring [Re: jlatessa] #2924448
05/19/21 02:44 PM
05/19/21 02:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
line boring
is the common term. Besides, its "boring". Things don't get aligned until you do the honing. And that's still called "line hoining"
Re: Line Boring [Re: Stanton] #2924451
05/19/21 02:49 PM
05/19/21 02:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
On a low deck motor the 440Source caps should only need honing as they're already cut to low deck main bore size. A different story on a RB. The caps need to be machined for the larger journal size. This was such a pain in the a$$ that I just returned the caps for credit and went with stockers.
Re: Line Boring [Re: Stanton] #2924456
05/19/21 03:01 PM
05/19/21 03:01 PM
Missouri
galen Offline
galen  Offline
Missouri
What about Reher Morrison. I know they have built a few hemis. If like the good machine shops up here the wait is long.
Re: Line Boring [Re: galen] #2924458
05/19/21 03:05 PM
05/19/21 03:05 PM
Texas
Chief Offline
Chief  Offline
Texas
Jack Hodson at Precision Machine in Waco. He does the machine work for me. He also races the Outlaw Fuel Altered circuit. 2544201818, or 2546667736
Dave Covey
Re: Line Boring [Re: ChrgrCuda] #2924463
05/19/21 03:15 PM
05/19/21 03:15 PM
AndyF Offline
AndyF  Offline
Line boring has fallen out of favor since most blocks don't require it anymore. You can buy new blocks from a number of vendors that are ready to go with just a line hone. Putting new caps on a block and boring the main line is rarely done anymore since it is expensive and time consuming. So I'm not surprised that you're finding it hard to find someone to do it. The sad thing is that your customer's block probably didn't even require those aftermarket caps. Stock caps should work okay on a 383, even if it is a stroker engine. But that is most likely water under the bridge by now.
Re: Line Boring [Re: AndyF] #2924684
05/19/21 10:35 PM
05/19/21 10:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
But there is a lot of hype around aluminum main caps - I think you even tout the benefits in your book. Andy.
Re: Line Boring [Re: Stanton] #2924714
05/19/21 11:58 PM
05/19/21 11:58 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
There are two places that align bore here in town. I think you need to cut the thrust area radially for the later style bearing with the 440 source caps.
As far as needing them or not....it's a hotrod. I have three building of impractical cars and parts that I could have substituted with cheaper versions. People have been using studs and aluminum caps with success for a long time.
If this package warrants the AL caps make it happen.
Also....
https://goodson.com/collections/sunnen-align-honing-supplies
Just sayin : D
Re: Line Boring [Re: AndyF] #2924731
05/20/21 07:21 AM
05/20/21 07:21 AM
Texas, USA
Texas, USA
Andy - The customer brought the block to me without the caps, as someone took them while his car was being restored by another shop. I had nothing to work with from the get go.
Re: Line Boring [Re: Chief] #2924732
05/20/21 07:22 AM
05/20/21 07:22 AM
Texas, USA
Texas, USA
Thank you Chief! I will give them a call!
Re: Line Boring [Re: ChrgrCuda] #2924758
05/20/21 09:30 AM
05/20/21 09:30 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
As already said, Reher Morrison
https://rehermorrison.com/
2011 Drag Pak Challenger
Re: Line Boring [Re: rickseeman] #2924761
05/20/21 09:33 AM
05/20/21 09:33 AM
Texas, USA
Texas, USA
Called twice. They never called me back.
Re: Line Boring [Re: Chief] #2924763
05/20/21 09:35 AM
05/20/21 09:35 AM
Texas, USA
Texas, USA
Thanks Chief! I called and they confirmed they can align hone the 383 with the new caps.
Thanks for the reference!!
Re: Line Boring [Re: ChrgrCuda] #2924832
05/20/21 12:35 PM
05/20/21 12:35 PM
Texas
Chief Offline
Chief  Offline
Texas
You are welcome. Jack is a good guy and has always treated me fair. Also, he just got a new machine for line bore/hone. The same machine also does cam tunnels (I asked.lol)
Dave Covey
