Page 3 of 3 1 2 3
Re: Radial Front Bias Ply Rear Staibility? [Re: racerx] #2923419
05/17/21 10:48 AM
05/17/21 10:48 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My experience with mixing bias rear and radial fronts has been mixed depending on the application. Essentially anything with big tires in the rear and skinny (5" or less) in the front seems to do okay. Not great but manageable swagger. On the other hand putting bias plys on the back of a car with regular size front street tires gets interesting, especially as you start airing them down in the rear. In that particular instance I replaced the front tires with some repro bias plys and the handling became that of a relatively predictable marshmallow. Just how bias ply always drove lol! My advice is to try it for 20 miles. You will know if it's going to work by the end of your test drive. All of my cars are manual transmission so an automatic might provide a little bit different experience.
ps somebody find the pledge to dust this thread off
Re: Radial Front Bias Ply Rear Staibility? [Re: Jeremiah] #2923473
05/17/21 12:20 PM
05/17/21 12:20 PM
moparx Offline
moparx  Offline
over the many, many years i have mixed and matched radials and bias ply tires, i have found a lot depends on two things, which really are six things.
wheel base and weight. then mix in skinny[er] fronts and wide[er] rears. add in differing air pressures [F-R] and as can be seen, there is a BUNCH of things boiling down to two differences, the front and rear tire combination on a specific vehicle.
theory may say the "particular combination" will not work, but the only sure fire way is to try it and see. just sneak up on the potential speed of your combination so as to safely learn the particulars of the combination's handling characteristics.
beer
Re: Radial Front Bias Ply Rear Staibility? [Re: moparx] #2923488
05/17/21 01:09 PM
05/17/21 01:09 PM
I had steering wandering issues with my old Duster with mix of bias and radials, it was caused by the unknown brand new idler arm wearing out real quickly after I had driven and raced it a very short while shock shruggy
Once I found that out and replace it with another new Moog brand one it was fixed up
Re: Radial Front Bias Ply Rear Staibility? [Re: Cab_Burge] #2924091
05/18/21 07:06 PM
05/18/21 07:06 PM
PA
moparacer Offline
moparacer  Offline
PA
I am about to find out what it is like with radials on the back and bias in the front on my Barracuda I and putting back on the street...
I guess its a "try it and see" approach?
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Radial Front Bias Ply Rear Staibility? [Re: LAR_414] #2924106
05/18/21 07:35 PM
05/18/21 07:35 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
Originally Posted by LAR_414
Ryan,
I've had similar issues. Here's what I think is going on with your car.
#1) Wheels aren't wide enough for your tire size iagree
#2) Need a stiffer sidewall via more air pressure or run tubes, or both.
Just my thoughts from years of messing with stuff on street cars.
Have fun and be safe!
Larry
how much movement do you have laterally speaking? you cant stabilize that much sidewall.. way to much tire for the rim. sidewall steering... a shock change will help but its not the real fix....
Page 3 of 3 1 2 3
