Re: It was a great weekend at the track, then it wasnt
[Re: gregsdart]
#2923619
05/17/21 06:57 PM
05/17/21 06:57 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have a virgin 68-70 (440HP) block that some idiot at a junkyard ripped out with a high lift and tore the engine mount off. It tore a hole in the block. I was going to scab a plate on it and pour the block full of cement. If it could get you up and running for awhile it’s all yours. I’m about 35 miles NE of pittsburgh.
[Re: pittsburghracer]
#2923623
05/17/21 07:05 PM
05/17/21 07:05 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
At least it wasn't like that famous black and white photo from the 60's of the Fiat Topolino where it was shot when the crank etc had just landed on the ground.
Carl Kessel
[Re: FastmOp]
#2923789
05/18/21 06:43 AM
05/18/21 06:43 AM
Posts: 10,022 MN
JERICOGTX
MN
What rods were in it Doug?
69 GTX
68 Road Runner
[Re: dvw]
#2923856
05/18/21 09:51 AM
05/18/21 09:51 AM
Posts: 10,022 MN
JERICOGTX
MN
The rod failure was caused by the bearing locking on the crank. Doug I have 4 Billet Oliver rods 7.10 length, that could find a new home, if needed. Why I was wondering.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2924078
05/18/21 06:41 PM
05/18/21 06:41 PM
Posts: 154 Canada
cuda499
Canada
The rod failure was caused by the bearing locking on the crank. Doug I have 4 Billet Oliver rods 7.10 length, that could find a new home, if needed. Why I was wondering. I have 6 oliver billets but they are 7.0 length
[Re: dvw]
#2924087
05/18/21 06:57 PM
05/18/21 06:57 PM
Posts: 2,498 PA
moparacer
PA
The rod failure was caused by the bearing locking on the crank. Doug That freaking blows. I have a policy of if it slows a few hundredths, then a few more, and I cant figure out why, it goes in the trailer, because I have seen too many windowed blocks from that happening over the years if you keep on running them.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Whompin_Wedge]
#2926065
05/24/21 08:53 AM
05/24/21 08:53 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Sorry to see this Doug! Lucky it wasn't bad enough to cause a crash. Hope you get it fixed up soon and get that 8!
[Re: an8sec70cuda]
#2926773
05/26/21 09:16 AM
05/26/21 09:16 AM
Posts: 9,835 MI, usa
dvw
MI, usa
Update; Block is being welded. The cracks aren't structural or into water. The #3 cylinder is getting sleeved. Machine work; bore to 4.530" (due to ring size availability) deck, line hone, valve job, skim cut heads, balance. New parts; crank and rods (Molnar), pistons (Ross), rings, bearings (Clevite), oil pump (Melling), valves (Ferrea), valve locks and springs (Pac), dampner (ATI). The cam, valve train all survived well. Pan has been straightened out and is ready to weld. The Fluidampner was cracked and leaking. All the reusable parts are cleaned and stored. Biggest holdup is pistons, 6-7 weeks. I was going to paint the outside of my house and shop this Summer. So soon I'll be at it. Hope to get the hood painted and some touch up as well while I'm waiting. Fortunately I've been hustling jobs out of the garage for the last couple of years to establish a fund to support my race habit. The fund just got smaller. Doug
[Re: dvw]
#2926874
05/26/21 12:00 PM
05/26/21 12:00 PM
an8sec70cuda
I hope your pistons get to you on time. I've been waiting on a set for a 440" SBC for over 2 months now. Ship time keeps getting bumped. Have another set I need to order in the next day or two for a 489" BBC...guess that one will be on hold for a while also.
