Re: Wheel studs 3in
[Re: RAY1969CARS]
#2923183
05/16/21 04:18 PM
05/16/21 04:18 PM
Posts: 11,799 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have. Don't like to. Aren't supposed to. Drilling, reaming, tapping not easy on some of the race axles (Strange) because of hardness. If I did, it would be with a TIG. Best bet is to send the back to the manufacturer and have them done for 5/8" stuff. Wheel stud problems over.
Re: Wheel studs 3in
[Re: merpar]
#2923190
05/16/21 04:34 PM
05/16/21 04:34 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Re: Wheel studs 3in
[Re: RAY1969CARS]
#2923271
05/16/21 09:07 PM
05/16/21 09:07 PM
Posts: 22,790 Bitopia
jcc
Bitopia
Any of you guys have to put a small weld on the back side ??? Or do you ream out n go to the next size ?? ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) Not something I could ever see myself doing or suggesting, regarding the tack weld. Another option for an upgrade is a 14mm stud, just slightly under 9/16", but increases tensile/clamping by nearly 20% over 1/2", or just go 5/8" and forget about it.
Re: Wheel studs 3in
[Re: Cab_Burge]
#2923320
05/16/21 10:30 PM
05/16/21 10:30 PM
jcc
Bitopia
Why not skip the tack weld and use a thin jam nut on the back side, that can be drilled for safety wire and/or lock-tite?
Re: Wheel studs 3in
[Re: jcc]
#2923350
05/17/21 12:34 AM
05/17/21 12:34 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The Strange screw in 5/8 stud kits come with jams. Red loctite and forget about it. Unless you have an axle with an unusually thick flange.
Re: Wheel studs 3in
[Re: CMcAllister]
#2923425
05/17/21 11:03 AM
05/17/21 11:03 AM
Posts: 43,359 Bend,OR USA
Cab_Burge
The Strange screw in 5/8 stud kits come with jams. Red loctite and forget about it. Unless you have an axle with an unusually thick flange. My 40 spline Mark Williams Dana 60 axles with their 5/8 inch studs have thin locknuts on the backside also ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
