Driveshaft Angle Demonstration #2921690
05/12/21 02:16 PM
05/12/21 02:16 PM
NW Illinois
MoonshineMattK Offline OP
NW Illinois
https://www.youtube.com/watch?v=gmV4qwLfOMY
Interesting video regarding u-joint speed oscillation resulting from the driveshaft angle
Re: Driveshaft Angle Demonstration [Re: MoonshineMattK] #2922075
05/13/21 11:48 AM
05/13/21 11:48 AM
moparx Offline
moparx  Offline
i have seen that before, and was amazed at the different angles dialed in and how that affected the joints.
beer
Re: Driveshaft Angle Demonstration [Re: moparx] #2922143
05/13/21 03:31 PM
05/13/21 03:31 PM
NW Illinois
NW Illinois
Video was new to me. Learned years ago to mark driveshafts before disassembly and have had to adjust the pinion angle on different vehicles. Had not taken into account the driveshaft would be accelerating and decelerating if not aligned correctly.
Re: Driveshaft Angle Demonstration [Re: MoonshineMattK] #2922228
05/13/21 08:25 PM
05/13/21 08:25 PM
Superfreak
Superfreak
You need a Thompson Constant Velocity Joint
Re: Driveshaft Angle Demonstration [Re: ] #2922423
05/14/21 11:40 AM
05/14/21 11:40 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Wonder how much they cost and how do they stay clean?
Re: Driveshaft Angle Demonstration [Re: cudaman1969] #2922477
05/14/21 02:11 PM
05/14/21 02:11 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
This is why set set the pinion angle in relation to the centerline of the transmission mainshaft, not to the ground as some have argued.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Driveshaft Angle Demonstration [Re: Hemi_Joel] #2922709
05/15/21 08:18 AM
05/15/21 08:18 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Then that begs the question; do you set them parallel at rest or at full throttle?
Which is more important for stability of the driveline?
Thanks, Joe
Re: Driveshaft Angle Demonstration [Re: jlatessa] #2922724
05/15/21 08:59 AM
05/15/21 08:59 AM
A727Tflite Offline
A727Tflite  Offline
Thanks, Joe
Depends on if it’s a race car or street driver.
All the hoopla about setting it parallel to the output shaft or to the ground leaves out one consideration, pinion angle is dynamic.
Re: Driveshaft Angle Demonstration [Re: A727Tflite] #2922727
05/15/21 09:30 AM
05/15/21 09:30 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Exactly what I was thinking, the car we're putting together now, (a 71 RR w/620 hp 512c.i.),
Is primarily going to be street, BUT, with that kind of HP & TQ,
should we limit the pinion reaction to suit both uses?
On our other car, (70 465 HP Charger) we use a pinion snubber to control this.
I know what some of the consensus is on snubbers, but I'm old school
and have had good results so far..
I have some clamps I can use on the forward leafs, which are std. hp leafs.
Thanks, Joe
Re: Driveshaft Angle Demonstration [Re: jlatessa] #2922753
05/15/21 10:26 AM
05/15/21 10:26 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I have never understood phasing can someone please explain??
Re: Driveshaft Angle Demonstration [Re: Blucuda413] #2922782
05/15/21 11:22 AM
05/15/21 11:22 AM
A727Tflite Offline
A727Tflite  Offline
On a one piece driveshaft, the front and rear weld joints should be welded on so the front and rear u joints are clocked the same.
On a multiple driveshaft arrangement - the joints should be clocked the same way.
That’s an oversimplified explanation but you should get the picture.
Re: Driveshaft Angle Demonstration [Re: A727Tflite] #2922797
05/15/21 12:10 PM
05/15/21 12:10 PM
moparx Offline
moparx  Offline
the u-joint ears of the driveshaft are in perfect alignment with each other.
beer
Re: Driveshaft Angle Demonstration [Re: moparx] #2922885
05/15/21 04:52 PM
05/15/21 04:52 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Ladder bars and 4 links keeps them close (under power) don’t matter riding around. Ever see a video of S/S springs and Cal Tracs On launch? Tremendous over angle = HP loss (you saw it stop in the vid when over angled). Oh no the dreaded pinion angle debate again!!
Re: Driveshaft Angle Demonstration [Re: moparx] #2922937
05/15/21 07:33 PM
05/15/21 07:33 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
That makes sense, Thanks!!!
Re: Driveshaft Angle Demonstration [Re: Blucuda413] #2923451
05/17/21 11:41 AM
05/17/21 11:41 AM
moparx Offline
moparx  Offline
as much as some hate the great pinion angle debate, youngsters come along [every so often] not knowing, and need taught. also, oldsters [like ME biggrin] forget "stuff".
learning and keeping knowledge depends on repetition. how many times in grade school did you get asked 2x2= ?????? laugh2
beer
Re: Driveshaft Angle Demonstration [Re: cudaman1969] #2923519
05/17/21 02:47 PM
05/17/21 02:47 PM
NW Illinois
NW Illinois
Didn't realize there was a pinion angle debate in the past. What were the opposing ideas?
Re: Driveshaft Angle Demonstration [Re: MoonshineMattK] #2923533
05/17/21 03:17 PM
05/17/21 03:17 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Now you gone and done it!
Maybe after seeing the video Chrysler’s idea of 3 degrees down, then under power straight, WAS a good thing.?!
Re: Driveshaft Angle Demonstration [Re: cudaman1969] #2923575
05/17/21 05:10 PM
05/17/21 05:10 PM
NW Illinois
NW Illinois
What angle other than 3deg down has been campaigned?
Re: Driveshaft Angle Demonstration [Re: MoonshineMattK] #2923616
05/17/21 06:45 PM
05/17/21 06:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
More of a debate whether it was needed or not.
Re: Driveshaft Angle Demonstration [Re: A727Tflite] #2923618
05/17/21 06:48 PM
05/17/21 06:48 PM
A727Tflite Offline
A727Tflite  Offline
Thanks, Joe
And it depends on what type of chassis setup you have. Ladder bars, Calverts, four link versus plain old springs.
All the Chrysler Tech tips back in the day advocated 5 degrees nose down on an automatic trans with SA springs.
With the engine in the stock location, etc.
Never had to worry about the front angle, just the back.
