2nd gen door weather strip questions #2922643
05/14/21 09:59 PM
05/14/21 09:59 PM
Missouri
StrokerPost Offline OP
Missouri
I have a 98 and now a 99 Ram Quad cab and I noticed the "down low end" of the outermost strip, at the base of the windshield is different between the 2 years. I am needing to replace one of these but I dont know what this one is called to search it, all I'm finding is the real long one that goes all the way around the entire door opening. Anyone ever replace these? Where did you find them and what are they called? Thanks for any help.
Re: 2nd gen door weather strip questions [Re: StrokerPost] #2922715
05/15/21 07:42 AM
05/15/21 07:42 AM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
go to mopar parts giant. fo;;ow the leads and type in your vin number and it should come up with the correct number.
Re: 2nd gen door weather strip questions [Re: trw1982] #2923237
05/16/21 06:57 PM
05/16/21 06:57 PM
Missouri
Missouri
Thanks for the info, unfortunately everything for these years is discontinued
Re: 2nd gen door weather strip questions [Re: StrokerPost] #2930423
06/05/21 10:51 PM
06/05/21 10:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
https://www.lmctruck.com/door-components/door-parts
Pretty sure I scored some of the last quad cab door seals kits at work as we had to acquire a couple of them from other dealer inventory. I did see these though in the catalog LMC sent with the dash I bought....
Re: 2nd gen door weather strip questions [Re: J_BODY] #2932403
06/12/21 01:14 AM
06/12/21 01:14 AM
Missouri
Missouri
Hey J BODY, been a long time, thanks a lot for the link, appreciate it! up
