Re: Ductile iron rockers vs. aluminum roller rockers? [Re: GY3] #2921991
05/13/21 08:17 AM
05/13/21 08:17 AM
an8sec70cuda Offline
You can't buy cheap aluminum rockers and expect them to last very long w/ big cams and high spring pressures.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Ductile iron rockers vs. aluminum roller rockers? [Re: mopardude318] #2922025
05/13/21 09:30 AM
05/13/21 09:30 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Thanks for the pictures.
What wall thickness are the bushings?
Boffin Emeritus
Re: Ductile iron rockers vs. aluminum roller rockers? [Re: polyspheric] #2922043
05/13/21 10:22 AM
05/13/21 10:22 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I miss the old Isky rockers that I used with the Max Wedge heads and solid tappet cams. Never had any problems. Switched to Indy 440-1s. Only rockers available that i know of are alum. So it's T&Ds
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Ductile iron rockers vs. aluminum roller rockers? [Re: jughed] #2922098
05/13/21 12:52 PM
05/13/21 12:52 PM
Jesel, T&D and maybe Harland sharp are making steel rocker now up scope
Re: Ductile iron rockers vs. aluminum roller rockers? [Re: Cab_Burge] #2922111
05/13/21 01:35 PM
05/13/21 01:35 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I ran 273 iron rockers on my 340s for years and iron ones on my W2 heads ,the biggest cam I used was a 627 lift roller and never had a problem, replaced one adjuster after many years. I will be using them again on my under construction/ rebuild W2 head 363.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Ductile iron rockers vs. aluminum roller rockers? [Re: VernMotor] #2922132
05/13/21 02:54 PM
05/13/21 02:54 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Originally Posted by VernMotor
I have had a set of Ductile iron rockers on my car for 30 years. race car. has a 640 lift cam in it now. I am building a new engine now and I bought new set of Harlem sharp rockets for it. We will see. I hope I am not disappointed.
We have a set of HS that have been in use since the 70's. The 1st three engines ran any where from low 10's to mid 11's They have been on my brothers GTX since 2002. Street strip car 500-1000 miles a yr.
Ok
Re: Ductile iron rockers vs. aluminum roller rockers? [Re: GY3] #2922144
05/13/21 03:31 PM
05/13/21 03:31 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Nice if there were some math to calculate time X stress to failure for aluminum rockers. We know most of the factors, but how much value for each?
Boffin Emeritus
