finding fuel filter UP DATED #2921949
05/13/21 12:07 AM
05/13/21 12:07 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
I was told that there is a fuel filter (or screen ) from either jegs or summit that is just a disc that you can clean. The person told me it just has.a disc and you unsrew the end and take the disc out to clean it. Any one seen these or has a part number I looked and could not find one. Thanks. Update should' of put inline filter said I could.put at the end of my fuel log. Thanks
Re: finding fuel filter [Re: dragon] #2921967
05/13/21 03:18 AM
05/13/21 03:18 AM
Boise
Moparteacher Offline
Boise
Reads like your asking about an Oberg or Clearview type filter.
Typically used as an oil filter, but I suppose you can use it as an fuel filter.
https://www.goodvibesracing.com/ClearViewFilters.htm
https://www.summitracing.com/parts/kys-100-68851
Re: finding fuel filter [Re: dragon] #2921989
05/13/21 08:06 AM
05/13/21 08:06 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Like this:
https://www.summitracing.com/parts/sum-230130
This one is for e85...I believe I have the 100 micron version of this on my car.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: finding fuel filter [Re: dragon] #2922030
05/13/21 09:49 AM
05/13/21 09:49 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I have two on my car (duel inlet on pump). They were rebranded and K&N used to sell them. I’ll have to research the OE manufacturer. Iirc when I found them I was shocked at the price
Similar to this....
https://www.speedwaymotors.com/Earls-230210ERL-In-Line-Fuel-Filter-10-AN-Red-Anodized,142980.html?sku=425230210ERL&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=EAIaIQobChMIiNmr5ObG8AIVoffjBx0oiwKYEAQYAiABEgLjSvD_BwE
Re: finding fuel filter [Re: J_BODY] #2922570
05/14/21 06:48 PM
05/14/21 06:48 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I use these filter screens in my dry sump oil lines to protect the pump, but they can be used in fuel lines as well. They just sandwich in between your AN fittings.
Re: finding fuel filter [Re: rebel] #2922594
05/14/21 08:14 PM
05/14/21 08:14 PM
up iagree
I run the same brand in my dual line Milidon up
