Page 1 of 3 1 2 3
Where to find Grade 8 Sex Bolts, Mating Screws? #2921695
05/12/21 02:32 PM
05/12/21 02:32 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
I am looking for Grade 8 sex bolts in a 1/2" to 5/8" diameter barrel with a grip range of 3" to 3-1/4".
Prefer to find a tapered seat style for a flush mount.
I can find them in 18-8 Stainless, but I would really like to have Grade 8.
Anyone know any sources for such fastener?
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2921697
05/12/21 02:35 PM
05/12/21 02:35 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
You might try your local bolt supplier and ask for A490 specs. Don't settle for A325.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2921701
05/12/21 02:38 PM
05/12/21 02:38 PM
Kirkland, Washington
Pacnorthcuda Offline
Sex bolts.......am I missing out on something here?
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: 3hundred] #2921702
05/12/21 02:39 PM
05/12/21 02:39 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Wait, tapered seat? You mean flat head? I know of no such thing.
'69 300 Convertible
'16 300 S Hemi
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Pacnorthcuda] #2921704
05/12/21 02:41 PM
05/12/21 02:41 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Yeah - sex bolts?
Might start with pichunter................
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Sunroofcuda] #2921719
05/12/21 03:18 PM
05/12/21 03:18 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Originally Posted by Sunroofcuda
Yeah - sex bolts?
Ah, c'mon, it was probably just a typo. He probably meant 8 sex bots...
'69 300 Convertible
'16 300 S Hemi
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Sunroofcuda] #2921720
05/12/21 03:19 PM
05/12/21 03:19 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Grainger online, then select store to see if in stock. McMaster has almost any kind of fasteners too.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Pacnorthcuda] #2921732
05/12/21 03:42 PM
05/12/21 03:42 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Doc should know....
paging doc,
paging doc
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2921735
05/12/21 03:55 PM
05/12/21 03:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Trying to decipher the OP. Is this what you're looking for:
https://www.portlandbolt.com/products/bolts/countersunk/
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2921767
05/12/21 05:23 PM
05/12/21 05:23 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: SNK-EYZ] #2921782
05/12/21 05:54 PM
05/12/21 05:54 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not sure you can find stainless in grade eight, or sex bolts in grade eight for that matter.
https://www.mcmaster.com/sex-bolts/...ng-barrels-and-screws-for-door-hardware/
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Sniper] #2921794
05/12/21 06:10 PM
05/12/21 06:10 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
These are what I can find in stainless steel.
However I would like to get them in just standard grade 8 steel.
https://www.mcmaster.com/sex-bolts/barrel-diameter~5-8/head-type~flat/for-material-thickness~3-1-4-3-1-2/
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #2921824
05/12/21 07:26 PM
05/12/21 07:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
These what you're after? When it comes to grading bolts not all types are graded in the conventional numeric way. Particularly when you're dealing with socket heads.
https://spaenaur.com/catalog/B200/#zoom=z
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Sniper] #2921841
05/12/21 08:15 PM
05/12/21 08:15 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Nope - you can't. I don't think you can harden stainless, even though it's already hard. No way stainless is grade 8. When you need grade 8, you need grade 8!
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Sunroofcuda] #2921893
05/12/21 09:46 PM
05/12/21 09:46 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Tell us what you're using them for
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: moparjim79] #2922027
05/13/21 09:36 AM
05/13/21 09:36 AM
IMGTX Offline
IMGTX  Offline
But please no pictures. I don't want to see what any one on here does with sex bolts.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Sunroofcuda] #2922047
05/13/21 10:40 AM
05/13/21 10:40 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
17-4 Stainless is available and very comparable strength wise to typical grade 8, and far superior to typical grade 2 stainless fasteners.
Physical Properties:
Melting Point: 2560 - 2625°F (1404 – 1440°C)
Density: 0.282 lbs/in3 / 7.8 g/cm3
Modulus of Elasticity in Tension: 28.5 X 106 psi / 197 GPa
Mechanical Properties:
Condition: Solution Treated (A)
Tensile Strength Minimum (psi): 160,000
Yield Strength Minimum 0.2% offset (psi): 145,000
% Elongation in 2” Typical: 5%
Hardness: Rockwell B85
Condition: Hardened + Aged (TH1050)
Tensile Strength Typical (psi): 200,000
Yield Strength Typical 2% offset (psi): 185,000
% Elongation in 2": 8%
Hardness: Rockwell C35
Condition: Aged (H1075)
Tensile Strength Typical (psi): 175,000
Yield Strength Typical 2% offset (psi): 165,000
Hardness: Rockwell C37
Condition: Aged (H900)
Tensile Strength Typical (psi): 210,000
Yield Strength Typical 2% offset (psi): 200,000
% Elongation in 2": 7%
Hardness: Rockwell C45
For reference sake, its likely double the cost of typical SS.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Hugh Jorgan] #2922064
05/13/21 11:19 AM
05/13/21 11:19 AM
Doc should know....
paging doc,
paging doc
And let’s not forget “mating screws”. Apparently there is a language of love that I never learned.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: Pacnorthcuda] #2922084
05/13/21 12:16 PM
05/13/21 12:16 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Doc should know....
paging doc,
paging doc
That's just redundant...pick one.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: jcc] #2922087
05/13/21 12:31 PM
05/13/21 12:31 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Irrelevant if no one makes sex bolts in 17-4 stainless.
Page 1 of 3 1 2 3
