cam help #292160
04/18/09 08:25 PM
04/18/09 08:25 PM
Florida, USA
hotrodsr1 Offline OP
Florida, USA
I have a 318 with a roller cam from factury and i have a hydraulic cam to pot in it, can this work going from roller to hydraulic?
Re: cam help [Re: hotrodsr1] #292161
04/18/09 10:00 PM
04/18/09 10:00 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
hydraulic roller to hydraulic flat tappet?
new cam and lifters...
longer pushrods that still oil thru them
you might have to address some issues at the front of the motor..
is it a magnum engine?
make sure you order the proper cam to fit inside the timing chain cover...
Tony
70 AARCuda Vitamin C
Re: cam help [Re: 70AARcuda] #292162
04/19/09 09:35 PM
04/19/09 09:35 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
just need to get flat tappet length pushrods. but if you have a roller cam, why not just get yours reground and reuse the OEM roller lifters? you can get the cam reground for probably $150 or less. you may need slightly longer pushrods after a regrind, as they get more lobe lift/duration by reducing the base circle.
bullet cams or delta cams in tacoma, WA, or hughes engines all regrind roller cams...
2017 Grand Cherokee Overland
Re: cam help [Re: patrick] #292163
04/25/09 08:42 PM
04/25/09 08:42 PM
Florida, USA
Florida, USA
Well here is what happoned i ordered a cam hydroulic and lifters ,timing chain.manifold and a set of magnum heads to convert my 318 to a magnum but when i tuke it apart it was a roller motor from factery so i kinda paniced and stopped to find out if i can still do the swap.
Re: cam help [Re: hotrodsr1] #292164
04/26/09 08:53 AM
04/26/09 08:53 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Get a different cam and reuse the factory roller lifters. This way you won't have to buy push rods, and will have a much better set-up with fast valve action.
