Re: Trim ring restoration [Re: autoxcuda] #2921375
05/11/21 08:56 PM
05/11/21 08:56 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Did you have to pry the crimp up to remove the backing ring? Is that a spot weld that is cut?
I was wondering if the spotweld can be cut, and the backing ring worked out of the crimp, then straighten and polish the presentation surface, work the backing ring back in, spread it in tension, clamp, and tack it.
Since I've never take one apart... this is all speculation on my part.
And I understand Rick keeping his secrets close, but with no new supply in sight, and he can't meet current market demand, I'd love to see someone else that can do it.
Re: Trim ring restoration [Re: Vert] #2921382
05/11/21 09:16 PM
05/11/21 09:16 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I restored all the trim rings on my Duster. I didn't do anything with the spot weld. I carefully loosened the pinch around the perimeter on the inside. The inner mounting portion flexed enough that I was able to gradually work it out of the outer portion in a manner like the reverse of installing a tire over the bead of a rim. After the two pieces are separated, you will have access to remove dings from the back surface. I put the 2 halves back together in reverse order and carefully closed the pinch seam.
This was my first attempt at working on Rallye wheels and I was very happy with how they turned out. Like all stainless steel work, it is a slow tedious process to get it to looking right but it can be done by the home car enthusiast.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Trim ring restoration [Re: Vert] #2921479
05/12/21 01:34 AM
05/12/21 01:34 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
And I understand Rick keeping his secrets close, but with no new supply in sight, and he can't meet current market demand, I'd love to seem someone else that can do it.
It’s been a while, so going off memory...
I believe I un-crimped, couldn’t get retainer out, then broke spot weld. Now, I may have not un-crimped as aggressive as FJRdoc did and that’s why I struggled.
I do notice a ridge in the 15” retainer that isn’t on the 14” retainer. That might prevent retainer from sliding out of the outer trim ring as easy as a 14”?
I haven’t disassembled a 14” to compare
Probably more important; the crimp lip is half the size on the 14” I have.
Some pics...
Retainer
DCF51C30-927D-4158-8E96-90C5374E1C3C.jpegC5BD7AF0-826B-4F12-94C4-31023DB23991.jpeg16876720-EA96-496C-8A94-C5612ED0158A.jpeg
Re: Trim ring restoration [Re: autoxcuda] #2921498
05/12/21 08:07 AM
05/12/21 08:07 AM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Thanks guys! These posts are why I love this forum!
Re: Trim ring restoration [Re: Vert] #2921575
05/12/21 11:11 AM
05/12/21 11:11 AM
So Cal
So Cal
Hope it helps.
Sorta tough to explain. So I took pics last night.
Re: Trim ring restoration [Re: On the edge 02] #2990603
11/30/21 06:54 PM
11/30/21 06:54 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Originally Posted by On the edge 02
Anyone have a current number for RM? Sent him my 14x6 trim rings back in Seotember and was told coming back to me in October 26 but still nothing. Getting worried here and just my original rings back. Anyone have any similar expirrences. Thanks guys
435-668-7062 One month turn around time is very optimistic in these times we are in. I am sure Ric will get them to you.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Trim ring restoration [Re: On the edge 02] #2990610
11/30/21 07:16 PM
11/30/21 07:16 PM
Midwest
O
On the edge 02 Offline
O
Midwest
Number worked and talked to RM and he's checking into my progress. Thanks GTX for the number. Great guy to talk to 👍
Re: Trim ring restoration [Re: On the edge 02] #2993659
12/09/21 03:54 PM
12/09/21 03:54 PM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
I used Rick as well. The job took way longer then expected and communication was spotty. Price was $160 for 1 15x7 but the job was perfect.
1970 Dodge Challenger T/A
