727 Valve Body #2921044
05/11/21 07:40 AM
05/11/21 07:40 AM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Converting a 1978 lockup 727 to a non lockup , will a 1971 valve body work ok , thanks
Re: 727 Valve Body [Re: 426lloyd] #2921072
05/11/21 09:12 AM
05/11/21 09:12 AM
A727Tflite Offline
A727Tflite  Offline
When you mean converting it, you simply do not want lockup. That’s it?
Re: 727 Valve Body [Re: A727Tflite] #2921116
05/11/21 11:11 AM
05/11/21 11:11 AM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Correct , just wanting to know if a 71 vb. will work with the 78 case that had the lockup vb .
Re: 727 Valve Body [Re: 426lloyd] #2921134
05/11/21 11:51 AM
05/11/21 11:51 AM
A727Tflite Offline
A727Tflite  Offline
If you want to disable lockup just block the lockup valve. No need to switch valves bodies. On the 78 there is a lockup module with an aluminum tube running to it.
Just block the valve by replacing the spring inside with a plug.
Re: 727 Valve Body [Re: 426lloyd] #2921142
05/11/21 12:13 PM
05/11/21 12:13 PM
Locomotion Offline
Locomotion  Offline
But I believe you can't use a standard converter unless you switch the pump/input shaft. Different splines?
Re: 727 Valve Body [Re: Locomotion] #2921144
05/11/21 12:19 PM
05/11/21 12:19 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Ok , that's what I've done , changed all that for non lockup , that is why I'm asking if the 71 vb will work with the 78 case.
Re: 727 Valve Body [Re: 426lloyd] #2922031
05/13/21 09:51 AM
05/13/21 09:51 AM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Anyone might know?
Re: 727 Valve Body [Re: 426lloyd] #2922046
05/13/21 10:29 AM
05/13/21 10:29 AM
scratchnfotraction Offline
IIRC yes the 71vb will fit the 78 727 as you have converted the spline/TC to non lock up.
IIRC the 71 VB will NOT have a PTK valve. you can use a housing/spring/valve from a /6 904 trans on the 71 VB for a PTK. (IIRC this is what I did for my 67-727 for PTK)
IIRC the 78 VB would have PTK with a downshift limiter built into it.
904 and 727 lock up trans I have had, I blocked the valve and order up a fresh lock-up TC with out the clutch ring/guts in the TC and use the non-lock up spline/shafts to save on teardown and parts.
but then again I have broke and killed more than I have ever been able to fix so hopefully someone will confirm for sure 100% + for you.
I have a good 78-727 VB on the parts shelf if you would prefer to use a 78 VB in the 78 case. PM me if you are interested.
Re: 727 Valve Body [Re: 426lloyd] #2922103
05/13/21 01:02 PM
05/13/21 01:02 PM
A727Tflite Offline
A727Tflite  Offline
Anyone might know?
I answered your question earlier. Why do you want to install a different valve body ?
Because you have a shift kit for that year or another reason?
If you want to disable lockup, just block the l/u valve in the module. The module is the aluminum unit with the aluminum tube running to it.
Re: 727 Valve Body [Re: A727Tflite] #2922107
05/13/21 01:19 PM
05/13/21 01:19 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Maybe I didn't explain it enough , l do not want a lockup 727 , I have non lockup stahl converter I want to use , changed the components for non lockup , and have a 1971 vb I wanted to use and was not sure if it would work in the 1978 case . I want to save the lockup vb for another time and the other parts . I thank you for the reply .
Re: 727 Valve Body [Re: 426lloyd] #2922118
05/13/21 02:08 PM
05/13/21 02:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you have replaced the front pump assembly, input shaft and rear clutch piston retainer to pre-'78 non-lockup parts (or '78-later non-lockup parts), then, yes you can use the '71 VB. The factory has stated that the lock-up case can be used for "prior model service".
Re: 727 Valve Body [Re: 426lloyd] #2922153
05/13/21 03:55 PM
05/13/21 03:55 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Thank you
