Driving technique to save a crossed up racecar on slicks?
#2920758
05/10/21 01:28 PM
05/10/21 01:28 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I've seen a whole lot of videos on the internet with drag race cars getting crossed up to the point of being out of control. It seems they are trying to correct by turning into the skid, but then it whips around the other way, and gyrates back and forth more each time until they lose it. Sometimes the slicks fold under and grab then the car rolls. Sometimes the slicks grab and drive them into the wall. I've seen guys loop it and continue straight down the track, as well as a couple videos where they blip the throttle on and off as they are correcting and somehow that seems to help them save it.
So what are the best driving techniques to try and keep it shiny side up and away from the wall if a guy would find himself in that circumstance?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Driving technique to save a crossed up racecar on slicks?
[Re: Hemi_Joel]
#2920759
05/10/21 01:30 PM
05/10/21 01:30 PM
Posts: 10,022 MN
JERICOGTX
MN
I've seen a whole lot of videos on the internet with race cars getting crossed up to the point of being out of control. It seems they are trying to correct by turning into the skid, but then it whips around the other way, and gyrates back and forth more each time until they lose it. Sometimes the slicks fold under an grab then the car rolls. Sometimes the slicks grab and drive them into the wall. I've seen guys loop it and continue straight down the track, as well as a couple videos where they blip the throttle on and off as they are correcting and somehow that seems to help them save it.
So what are the best driving techniques to try and keep it shiny side up and away from the wall if a guy would find himself in that circumstance? Never, ever get back in the throttle, and pull the chute...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2920764
05/10/21 01:58 PM
05/10/21 01:58 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Short wheelbase cars are generally the worst. The ackerman angle toes the front tires out more and more In a correction as the wheelbase shortens. My dart has no ackerman built into it. Stays dead parallel lock to lock. Recovers very, very well. But it is a be it ch to push around a corner!
[Re: 69dart]
#2920782
05/10/21 02:58 PM
05/10/21 02:58 PM
Hemi_Joel
Minnesota
When I went to the Frank Hawley Drag racing school, he said "If you get out of the groove lift. If you lift, the pass is over." I think that is very safe advise. But still, I'm curious why some guys blip the throttle.
[Re: Hemi_Joel]
#2920798
05/10/21 03:47 PM
05/10/21 03:47 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I agree with the above, out of the gas and as little steering input as possible.
I ran into some crap in the traps a few weeks ago at TNT and was potentially saved by the rev limiter. It spun the tires from 127-135 instantly and all I felt was a little wiggle. This may have been different if it happened somewhere down track where the delta from my RPM to the limiter was greater than just a couple of hundred RPM. It has made me want to get traction control working, I have the sensors in place just haven't set the software side up.
68 Barracuda Formula S 340
[Re: 69dart]
#2920811
05/10/21 04:05 PM
05/10/21 04:05 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
You gotta know when to lift and live for another day.
Its like driving on ice - always use the least amount of steering input as possible.
The more you overdrive the worse things get. Actual seat time is your friend, don't over correct Gentle on the corrections, especially after the first hundred feet I've been sideways more than once past the 330 clocks in someone else's guuk, tranny oil, rear end grease and or motor oil or coolant that the starter didn't see happen until I got sideways in it, NOT GOOD Be safe, live longer
[Re: Hemi_Joel]
#2920816
05/10/21 04:19 PM
05/10/21 04:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
My car is very short.. I only lost control twice.. once when I blew a front tire and I ended up in the other lane and the other time I broke a tie rod end... all I can say is if you loose control,no matter the reason your pass is DONE.. never get back on it.. and your car better be set up right so you dont loose control
[Re: 69dart]
#2920865
05/10/21 06:13 PM
05/10/21 06:13 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
The more you overdrive the worse things get. Yep, if people quit imitating the dumb-assary they see on street outlaws of sawing the wheel back and forth and trying to save every bad pass when there opponent is 20 car lengths ahead less wrecks would happen. If thinks aren't going well abort.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: HemiDart68]
#2920867
05/10/21 06:19 PM
05/10/21 06:19 PM
Hemi_Joel
Minnesota
The more you overdrive the worse things get. Yep, if people quit imitating the dumb-assary they see on street outlaws of sawing the wheel back and forth and trying to save every bad pass when there opponent is 20 car lengths ahead less wrecks would happen. If thinks aren't going well abort. That is dead on. The folly of staying in it when you are out of the groove, out of shape, and have zero hope of winning.
[Re: Hemi_Joel]
#2920871
05/10/21 06:27 PM
05/10/21 06:27 PM
gregsdart
I totally agree on lifting at the slightest hint of trouble. If you can feel something at all the run is junk. So i tell myself before every pass to keep this in mind!
[Re: gregsdart]
#2920876
05/10/21 06:40 PM
05/10/21 06:40 PM
Hemi_Joel
Minnesota
Short wheelbase cars are generally the worst. The ackerman angle toes the front tires out more and more In a correction as the wheelbase shortens. My dart has no ackerman built into it. Stays dead parallel lock to lock. Recovers very, very well. But it is a be it ch to push around a corner! very interesting. I've never heard of doing that before. Did you design it or modify it for that purpose?
[Re: RustyM]
#2920930
05/10/21 08:59 PM
05/10/21 08:59 PM
Guitar Jones
My rule was give it a little correction, if it doesn't respond, lift, it's over and never, ever get back in it.
[Re: dvw]
#2920981
05/10/21 10:27 PM
05/10/21 10:27 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Interesting replies. My suspicion is the mentioned "overcorrection", might be really be initially a case of a "too slow correction" and over correcting is the second mistake..
Another aspect not yet mentioned, if you want to reduce traction on the rear axle, lifting should do the trick, as all rear weight transfer goes away. With a rear weight biased car, that should increase the pucker factor.
I do agree on the Kenny Rogers thinking.
Please note, I am not a drag racer.
In road racing, keeping your foot in it, which sometimes is the opposite of what you normal survival instincts are, is the right thing, and drive out of the skid.
[Re: geo.]
#2920997
05/10/21 11:07 PM
05/10/21 11:07 PM
Hemi_Joel
Minnesota
Mopar Muscle magazine ran a feature on a guy with a Challenger a while back, he raced in one of the "stock appearing" classes. Reading the story, i discovered he'd hit the wall not once, but twice at the strip. Reading the story further, I discovered he had a spool in the rear. I believe a spool can be a factor in many of these wall-banging events. And I agree, assume the run is over, let off the gas and slow down as smoothly as possible.
That was Tom Cannon. If I remember right the first time he scraped the wall his crankshaft threw a chunk of Mallory metal out through the pan. The other one I think he drove over some antifreeze on the track from a previous car that the track workers had not noticed. I found that driving my 750 horse stock appearing F.A.S.T. car on g70 14's with a spool is like dirt tracking. You just steer the right direction, lift a little bit if needed to try and help the tires catch up. The tires are so stiff, and you have so little traction, they're not going to catch and drive you into the wall or fold under and roll you. I think it is a lot safer than slicks.
