Hi All,
We run Top sportsman here in Australia with a Chrysler Lebaron powered by a 500ci solid kB block b1 headed engine. Engine was originally built by the previous owner to be a n/a engine with a methanol carb. Car ran 8.6 n/a than I fitted a direct port nitrous kit adding race gas for enrichment. 200 shot 8.15 than 300 shot 7.84.
We have just hurt the rings/pistons and will need to build a nitrous friendly engine.
My question is has anyone successfully run water cooled only heads with a solid KB block so that I can run run race gas through both the carb and nitrous?
