340 crank into 360 block bearing spacers #2919675
05/07/21 01:17 PM
05/07/21 01:17 PM
Charlotte, NC
LSP Offline OP
LSP  Offline OP
Charlotte, NC
Anyone make bearing spacers to put a 340 crank into a 360 block?
Re: 340 crank into 360 block bearing spacers [Re: LSP] #2919680
05/07/21 01:23 PM
05/07/21 01:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What will you do about the rear seal situation?
Re: 340 crank into 360 block bearing spacers [Re: LSP] #2919682
05/07/21 01:36 PM
05/07/21 01:36 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
I want to say Mancini used to sell something like that. But like Mr. Porter I also wonder about the rear seal situation.
68 Barracuda Formula S 340
Re: 340 crank into 360 block bearing spacers [Re: LSP] #2919832
05/07/21 10:35 PM
05/07/21 10:35 PM
Why would you want to do that? confused
Re: 340 crank into 360 block bearing spacers [Re: Bad340fish] #2919968
05/08/21 12:38 PM
05/08/21 12:38 PM
moparx Offline
moparx  Offline
if bearing spacers were to be used, wouldn't the 360 pan still be used with the 360 rear main cap ? or am i missing something ? shruggy
beer
Re: 340 crank into 360 block bearing spacers [Re: moparx] #2919977
05/08/21 12:56 PM
05/08/21 12:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
beer
Thats the way I thought it would be.. but as far as I know you would just use 360 seals shruggy
wave
Re: 340 crank into 360 block bearing spacers [Re: MR_P_BODY] #2919986
05/08/21 01:07 PM
05/08/21 01:07 PM
Tulsa OK
Tulsa OK
I think the rear main seal is what is in question.
Re: 340 crank into 360 block bearing spacers [Re: Bad340fish] #2919990
05/08/21 01:18 PM
05/08/21 01:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would have thought that a stock 360 seal would still fit the block
wave
Re: 340 crank into 360 block bearing spacers [Re: MR_P_BODY] #2919991
05/08/21 01:32 PM
05/08/21 01:32 PM
So. Burlington, Vt.
So. Burlington, Vt.
I don’t believe the seal surface diameter is the same between a 318/340 crank and a 360 crank(I believe the 360 is larger)....... but a quick measurement would clear that up.
Re: 340 crank into 360 block bearing spacers [Re: fast68plymouth] #2919997
05/08/21 01:44 PM
05/08/21 01:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 360 seal is larger and it fits into the block(2 pieces, top and bottom) and the bearings fit the
block
wave
Re: 340 crank into 360 block bearing spacers [Re: MR_P_BODY] #2920008
05/08/21 02:01 PM
05/08/21 02:01 PM
So. Burlington, Vt.
So. Burlington, Vt.
The seal has to fit the block.......and the crank.
If the seal surface for a 340 crank is .200-.300 smaller than a 360 crank..... the 360 seal won’t even be touching the 340 crank.
Re: 340 crank into 360 block bearing spacers [Re: fast68plymouth] #2920009
05/08/21 02:04 PM
05/08/21 02:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats why I think the old rope seal would work(if you can still find the rope seal)
wave
Re: 340 crank into 360 block bearing spacers [Re: MR_P_BODY] #2920017
05/08/21 02:15 PM
05/08/21 02:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’ve never really looked into it before....... but it appears as though the 340 seal surface might actually be a larger than the 360 seal surface.
If that’s the case, then the seal surface on the 340 crank could just be turned down to the 360 size.
Re: 340 crank into 360 block bearing spacers [Re: fast68plymouth] #2920023
05/08/21 02:23 PM
05/08/21 02:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I never looked into it either but yes the crank area could be cut down to fit(I believe).. all my
engines have been 340s and I never looked into the 360s(except one B and one RB engines)
wave
Re: 340 crank into 360 block bearing spacers [Re: MR_P_BODY] #2920207
05/08/21 10:20 PM
05/08/21 10:20 PM
The rear main cap outer diameter is way different, smaller, on the 360 motors compared to all the other SB Mopars, so the oil pan rear seals are not interchangeable along with the oil pans also scope
Re: 340 crank into 360 block bearing spacers [Re: Cab_Burge] #2920220
05/08/21 10:52 PM
05/08/21 10:52 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The reason I milled my 340 cap so a Magnum rear sump pan will fit
Re: 340 crank into 360 block bearing spacers [Re: Cab_Burge] #2920247
05/09/21 12:29 AM
05/09/21 12:29 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Indeed. You lose over a quarter inch of stroke with a smaller bore. A stock 360 crank will take a surprising amount of abuse. The high RPM oiling is the catch. Keep it below maybe 6800 if you don't want to redo the oil system. I put a 360 crank in a 340 and it turned into a rod bearing eating PIA.
