Bearing clearance- how much is too much? #2919264
05/06/21 11:29 AM
05/06/21 11:29 AM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Trying to assemble a 500" RB and I have two different sets of main bearings, King HP's & Speed pro 's. The King MB5116HP's (STD) are at .0025" and the Speed Pro M119 are at .0040". I would like to be at .0030"-.0035" The most logical solution would be a a set of King STD X's, but I can't find anyone that has them. Any suggestions?
Thanks, Brian
Re: Bearing clearance- how much is too much? [Re: '72CudaRacer] #2919269
05/06/21 11:47 AM
05/06/21 11:47 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Given the choice of too tight and too loose, i will go loose every time. That being said i would stick the M119's in it and not give it a second thought.
There is a old saying " if your clearances are too loose, only you will know it, if they are too tight, everybody will know it".
Joe
Without Data, you’re just another guy with an opinion.
Re: Bearing clearance- how much is too much? [Re: '72CudaRacer] #2919273
05/06/21 11:50 AM
05/06/21 11:50 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We mocked up our 540 using Clevite 2324P and had .0029 but wanted more so we ordered 119M and that gave us .0033 which is great for our application. Maybe the 2324P would give you the clearance you are looking for (.0004 tighter in our block) The 119M was much tighter on the thrust and we had to work on that to get thrust clearance we needed.
Is this street or strip set up for you?
Re: Bearing clearance- how much is too much? [Re: cl440] #2919291
05/06/21 12:14 PM
05/06/21 12:14 PM
Mooresburg, Tn
Mooresburg, Tn
Drag race only, 5.80's eight mile.
Brian
Re: Bearing clearance- how much is too much? [Re: '72CudaRacer] #2919312
05/06/21 12:35 PM
05/06/21 12:35 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've run .004"before. Bearings looked the same as they did close to .003" No real difference in oil pressure either. Better a little lose than too tight.
Doug
Re: Bearing clearance- how much is too much? [Re: dvw] #2919348
05/06/21 01:28 PM
05/06/21 01:28 PM
Doug
iagree Me Too up
Re: Bearing clearance- how much is too much? [Re: Cab_Burge] #2919364
05/06/21 02:06 PM
05/06/21 02:06 PM
PA
moparacer Offline
moparacer  Offline
PA
.004 here a couple times too.
You can always run gear oil in it to get the pressure up! drumhit
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Bearing clearance- how much is too much? [Re: moparacer] #2919394
05/06/21 03:55 PM
05/06/21 03:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Almost all the engines I have built(small and big blocks)have been between .0029 and .0036 ans one at
.0022 and it cooked a bearing.. went back and opened it upon all to.0032... not much but it worked on all
of my engines.. I did run a old alum rod engine at .0046
wave
Re: Bearing clearance- how much is too much? [Re: MR_P_BODY] #2919400
05/06/21 04:10 PM
05/06/21 04:10 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
back in the days they put aluminum foil back side of bearing to tighten up smile
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Bearing clearance- how much is too much? [Re: '72CudaRacer] #2919408
05/06/21 04:34 PM
05/06/21 04:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The gauge shows what the relief valve says.
It's not the local pressure at each bearing, or an average.
Loose clearance insures that the pressure drop between the first and last bearings in a gallery is higher than a small clearance.
My conclusion: .004" is safer than too small, but stay away from the 0W20 stuff.
BTW: .001" clearance per inch of journal diameter was industry standard 100 years ago.
Boffin Emeritus
Re: Bearing clearance- how much is too much? [Re: 440lebaron] #2919451
05/06/21 06:43 PM
05/06/21 06:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I was a kid I watched my dad working on a Chevy 6 cyl .. he had spun a rod bearing(pretty sure
it was a rod).. he pulled the bearing and lowered the crank ... he got some emery paper at a hardware
and smoothed out the crank(as good as you can by hand.. cut a chunk of his belt off.. enough for a
upper and lower bearing and put it back together using the old oil.. had to add a couple of qts of oil
but we made it back home .. this was on our Deer hunting trip about 140 miles from home... he got another
junk yard engine when we got home.. I pretty much said I was gonna become a mech at that point
wave
Re: Bearing clearance- how much is too much? [Re: MR_P_BODY] #2919470
05/06/21 07:37 PM
05/06/21 07:37 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Soviet "repair" of needle bearings in Harley-Davidson WW2 military bikes, when no needles are available?
Cut pieces of coat hangar to length, pack with heavy grease.
Sell the bike.
Boffin Emeritus
Re: Bearing clearance- how much is too much? [Re: polyspheric] #2919473
05/06/21 07:46 PM
05/06/21 07:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sell the bike.
Love the last line... SELL THE BIKE
wave
Re: Bearing clearance- how much is too much? [Re: MR_P_BODY] #2919478
05/06/21 08:06 PM
05/06/21 08:06 PM
SW CO
HemiSportFury Offline
SW CO
wave
Chevy 6's had babbit rod bearings into the early 50's. That was a very common roadside repair in the days of babbit bearings. Insert bearing made it more difficult because the insert was a lot thinner so the leather that thin wouldn't last long. But, if your choice is make the repair or walk home...
Wouldn't it be nice to be able to make roadside repairs like that today? But today's car are usually much more reliable.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Bearing clearance- how much is too much? [Re: polyspheric] #2919536
05/06/21 10:35 PM
05/06/21 10:35 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
Interesting responses. I'm absolutely not disagreeing with anyone here as everyone seems experienced and knowledgeable. In all the B and RB builds I've put together I've shot for .0025" on the mains, but would have been comfortable up to .003". Being that I've never ran an engine as loose as .004 I have no experience to say it's a bad idea, but my concern would be oil pressure.
I'm currently assembling a 289 Ford. My mains are just shy of .0015" and it feels a bit tight to me although it's within factory spec. I'd be more comfortable with .002 on the smaller 289 journal.
Point being, old factory specs are much tighter than many of us like to run, even at a time when oil technology was inferior to what we have today.
To the topic starter, I would have recommended the .0025 bearing without hesitation, but it seems like you might be okay a little looser. Happy Racing!
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Bearing clearance- how much is too much? [Re: '72CudaRacer] #2919651
05/07/21 12:04 PM
05/07/21 12:04 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
When we were searching for a bit less clearance on a set of bearings we had them coated and it worked like a charm.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
