Fuel pump safety shut off? #2918486
05/04/21 03:24 PM
05/04/21 03:24 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Who is using some type of automatic fuel pump shut off in case of a crash? I've heard of oil pressure switch and impact sensor. For the oil pressure switch to work, the engine has to die, that might not always happen soon enuff. An impact type could potentially cry wolf on a hard launch in the final round after you've clawed you way thru a 132 car field. whiney
So who uses what, how is it working out?
Thanks,
Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Fuel pump safety shut off? [Re: Hemi_Joel] #2918528
05/04/21 04:43 PM
05/04/21 04:43 PM
gregsdart Offline
gregsdart  Offline
How about a Ford starter relay at the positive battery terminal, with a very large mushroom head switch next to the shifter to control it? In a panic situation just slap the button and shut the whole electrical system down. You could also leave the safety switch on so you don't have to unbuckle if you forget!
Re: Fuel pump safety shut off? [Re: gregsdart] #2918547
05/04/21 05:08 PM
05/04/21 05:08 PM
Minnesota
Minnesota
The easy to get at master switch is a great thing, but what if you get beaned and go unconscious or pass out from medical reasons or something? I think that's where an automatic system comes into play.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Fuel pump safety shut off? [Re: Hemi_Joel] #2918553
05/04/21 05:14 PM
05/04/21 05:14 PM
Sounds like your looking for a dead man switch like the Railroads use work shruggy
Re: Fuel pump safety shut off? [Re: Hemi_Joel] #2918556
05/04/21 05:23 PM
05/04/21 05:23 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
This is what i use on mine and my customers
https://www.ebay.com.au/itm/2746478...Stfqw8AIVEayWCh2VvQbKEAQYBSABEgK78PD_BwE
Its a tachometric relay . Ignition on no run 3-5 seconds of power to pump . So you can prime if fuel empty etc . Will shut off when no tacho signal .
Very reliable , but if it fails easily bypassed
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Fuel pump safety shut off? [Re: tex013] #2918565
05/04/21 05:38 PM
05/04/21 05:38 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My EFI will only run the fuel pump when it has crank signal. The problem is EFI can run upside down I imagine so the engine is probably less likely to die unless it takes a direct impact to the crank sensor. Hmmm
68 Barracuda Formula S 340
Re: Fuel pump safety shut off? [Re: Bad340fish] #2918579
05/04/21 06:08 PM
05/04/21 06:08 PM
GA
roadrunninMark Offline
GA
I found this comtroller on amazon, price doesn’t seem bad.. https://smile.amazon.com/Revolution...itch+cp30&qid=1620165617&sr=8-13
I do like the idea of the ford stater relay.
Re: Fuel pump safety shut off? [Re: Hemi_Joel] #2918623
05/04/21 08:15 PM
05/04/21 08:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I have the ford style steel ball electrical cutoff on my cars. I road race. I have set mine off at a inappropriate time, like on off course spin, that then strands the car with approaching traffic. The easy fix was to relocate it so from the drivers seat i could reset it, and get underway. I don't see how a "hard launch" could set it off, unless the gyrations got rather extreme. It seems to need a hard impact, and I'm keeping mine as is.I think they are smart. The street cars get one easy to "kick' as I'm exiting in a potential car jacking(?), leaving the car running long enough to get some distance between me and the gun toting thug driving away.
Re: Fuel pump safety shut off? [Re: Hemi_Joel] #2918692
05/04/21 10:48 PM
05/04/21 10:48 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I use an oil pressure switch, but also added two bypass switches. One to prime the system, the other to disable it for anti-theft. I also have a nitrous type trigger switch on my outboard carbs to kick the pump up to high speed when they are opened. I run a Fuel Labs 2 speed pump.
Of course the switches including the oil pressure switch only interrupt the low amp side of the relays, or the trigger voltage. I use 2 40 amp Bosch relays to feed the fuel pump.
Re: Fuel pump safety shut off? [Re: jbc426] #2918858
05/05/21 12:35 PM
05/05/21 12:35 PM
moparx Offline
moparx  Offline
what kind of sensors do factory auto-shutdown systems use ?
i realize they run through the PCM, but they use some kind of sensors don't they ?
if so, would it be possible to utilize or modify a couple of factory sensors ?
beer
Re: Fuel pump safety shut off? [Re: moparx] #2919168
05/06/21 03:54 AM
05/06/21 03:54 AM
Farnham, Quebec Canada
Erick Char Offline
Erick Char  Offline
Most of today's car utilize Air Bag modules with a mix of internal and external sensors, when they detect an impact they send a Fuel Pump cut-off signal through a Bus line to the Engine or Fuel pump module.
Re: Fuel pump safety shut off? [Re: Hemi_Joel] #2920665
05/10/21 09:55 AM
05/10/21 09:55 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
I use oil pressure switch to ground the relay.
The switch is the same one Mr Gasket used to sell, it is sourced from a 1974 Chevrolet Vega.
There is a matching plug/connector available for it from the same application.
It's not a perfect solution, but at least gives one layer of protection compared to full manual.
Rich H.
Esse Quam Videri
Re: Fuel pump safety shut off? [Re: ZIPPY] #2920688
05/10/21 10:47 AM
05/10/21 10:47 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Story about the Vega oil pressure switch. Years ago living in the Seattle area I was looking for a project and kept noticing a really nice Orange Vega GT wagon on the back side of the Ford used car lot. After noticing it hadn't moved in a few weeks I dropped by and spoke to one of the salesmen. He finally admitted that they would sell it at a give-away price because they couldn't get it started. After settling on a great price I asked him if he would throw in a couple quarts of oil which he did. I poured the oil in the engine and it cranked right up. He was amazed and was really ticked because their mechanics didn't know that. That nice little car became my 350/turbo 350 daily driver. Loved that thing!!
Re: Fuel pump safety shut off? [Re: Blucuda413] #2920734
05/10/21 12:24 PM
05/10/21 12:24 PM
moparx Offline
moparx  Offline
that vega story reminded me about the vega my brother owned when he was in high school.
he always carried around a 5 gallon jug of oil in that thing because it used so much oil, and acted the same way when it was down a few quarts. laugh2
beer
Re: Fuel pump safety shut off? [Re: moparx] #2920804
05/10/21 03:55 PM
05/10/21 03:55 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
beer
Yep, Vega's had a three terminal oil pressure switch, and one of the terminals grounded the electric fuel pump. If you didn't have oil pressure, you had a fuel pump that didn't work, so no fuel to the carb. My Vega never let me down, but I did carry a shovel in back cause they could get hung up in snow drifts. In 1974, I sold my daily driver for more than I was asking due to the gas shortage. I never had a gas shortage, cause where I worked we sold Stoddard solvent, which burned just fine when mixed half and half with gasoline, and was even cheaper than gas at the time.
