Fuel pump safety shut off?
#2918486
05/04/21 03:24 PM
05/04/21 03:24 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Who is using some type of automatic fuel pump shut off in case of a crash? I've heard of oil pressure switch and impact sensor. For the oil pressure switch to work, the engine has to die, that might not always happen soon enuff. An impact type could potentially cry wolf on a hard launch in the final round after you've clawed you way thru a 132 car field. ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) So who uses what, how is it working out? Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Fuel pump safety shut off?
[Re: Hemi_Joel]
#2918528
05/04/21 04:43 PM
05/04/21 04:43 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
How about a Ford starter relay at the positive battery terminal, with a very large mushroom head switch next to the shifter to control it? In a panic situation just slap the button and shut the whole electrical system down. You could also leave the safety switch on so you don't have to unbuckle if you forget!
[Re: gregsdart]
#2918547
05/04/21 05:08 PM
05/04/21 05:08 PM
Hemi_Joel
Minnesota
The easy to get at master switch is a great thing, but what if you get beaned and go unconscious or pass out from medical reasons or something? I think that's where an automatic system comes into play.
[Re: Hemi_Joel]
#2918556
05/04/21 05:23 PM
05/04/21 05:23 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
This is what i use on mine and my customers https://www.ebay.com.au/itm/2746478...Stfqw8AIVEayWCh2VvQbKEAQYBSABEgK78PD_BwEIts a tachometric relay . Ignition on no run 3-5 seconds of power to pump . So you can prime if fuel empty etc . Will shut off when no tacho signal . Very reliable , but if it fails easily bypassed Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2918565
05/04/21 05:38 PM
05/04/21 05:38 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
My EFI will only run the fuel pump when it has crank signal. The problem is EFI can run upside down I imagine so the engine is probably less likely to die unless it takes a direct impact to the crank sensor. Hmmm
68 Barracuda Formula S 340
[Re: Hemi_Joel]
#2918623
05/04/21 08:15 PM
05/04/21 08:15 PM
Posts: 22,734 Bitopia
jcc
Bitopia
I have the ford style steel ball electrical cutoff on my cars. I road race. I have set mine off at a inappropriate time, like on off course spin, that then strands the car with approaching traffic. The easy fix was to relocate it so from the drivers seat i could reset it, and get underway. I don't see how a "hard launch" could set it off, unless the gyrations got rather extreme. It seems to need a hard impact, and I'm keeping mine as is.I think they are smart. The street cars get one easy to "kick' as I'm exiting in a potential car jacking(?), leaving the car running long enough to get some distance between me and the gun toting thug driving away.
[Re: Hemi_Joel]
#2918692
05/04/21 10:48 PM
05/04/21 10:48 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I use an oil pressure switch, but also added two bypass switches. One to prime the system, the other to disable it for anti-theft. I also have a nitrous type trigger switch on my outboard carbs to kick the pump up to high speed when they are opened. I run a Fuel Labs 2 speed pump.
Of course the switches including the oil pressure switch only interrupt the low amp side of the relays, or the trigger voltage. I use 2 40 amp Bosch relays to feed the fuel pump.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2918858
05/05/21 12:35 PM
05/05/21 12:35 PM
Posts: 19,648 north of coder
moparx
what kind of sensors do factory auto-shutdown systems use ? i realize they run through the PCM, but they use some kind of sensors don't they ? if so, would it be possible to utilize or modify a couple of factory sensors ? ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Hemi_Joel]
#2920665
05/10/21 09:55 AM
05/10/21 09:55 AM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
I use oil pressure switch to ground the relay.
The switch is the same one Mr Gasket used to sell, it is sourced from a 1974 Chevrolet Vega. There is a matching plug/connector available for it from the same application.
It's not a perfect solution, but at least gives one layer of protection compared to full manual.
Rich H.
Esse Quam Videri
[Re: moparx]
#2920804
05/10/21 03:55 PM
05/10/21 03:55 PM
Posts: 1,850 South Bend
John Brown
South Bend
that vega story reminded me about the vega my brother owned when he was in high school. he always carried around a 5 gallon jug of oil in that thing because it used so much oil, and acted the same way when it was down a few quarts. Yep, Vega's had a three terminal oil pressure switch, and one of the terminals grounded the electric fuel pump. If you didn't have oil pressure, you had a fuel pump that didn't work, so no fuel to the carb. My Vega never let me down, but I did carry a shovel in back cause they could get hung up in snow drifts. In 1974, I sold my daily driver for more than I was asking due to the gas shortage. I never had a gas shortage, cause where I worked we sold Stoddard solvent, which burned just fine when mixed half and half with gasoline, and was even cheaper than gas at the time.
