Re: Ductile iron rockers vs. aluminum roller rockers?
[Re: GY3]
#2921991
05/13/21 08:17 AM
05/13/21 08:17 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
You can't buy cheap aluminum rockers and expect them to last very long w/ big cams and high spring pressures.
[Re: mopardude318]
#2922025
05/13/21 09:30 AM
05/13/21 09:30 AM
Posts: 4,206 New York
polyspheric
New York
Thanks for the pictures. What wall thickness are the bushings?
Boffin Emeritus
[Re: Cab_Burge]
#2922111
05/13/21 01:35 PM
05/13/21 01:35 PM
Posts: 4,977 new jersey usa
11secdart
new jersey usa
I ran 273 iron rockers on my 340s for years and iron ones on my W2 heads ,the biggest cam I used was a 627 lift roller and never had a problem, replaced one adjuster after many years. I will be using them again on my under construction/ rebuild W2 head 363.
[Re: VernMotor]
#2922132
05/13/21 02:54 PM
05/13/21 02:54 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
I have had a set of Ductile iron rockers on my car for 30 years. race car. has a 640 lift cam in it now. I am building a new engine now and I bought new set of Harlem sharp rockets for it. We will see. I hope I am not disappointed. We have a set of HS that have been in use since the 70's. The 1st three engines ran any where from low 10's to mid 11's They have been on my brothers GTX since 2002. Street strip car 500-1000 miles a yr.
Ok
[Re: GY3]
#2922144
05/13/21 03:31 PM
05/13/21 03:31 PM
polyspheric
New York
Nice if there were some math to calculate time X stress to failure for aluminum rockers. We know most of the factors, but how much value for each?
Boffin Emeritus
