Factory Under Coat #2918423
05/04/21 01:13 PM
05/04/21 01:13 PM
Thomaston, CT
Frankie P Offline OP
Thomaston, CT
What is the closet undercoat to original that can be purchased?
Doing the under sides of my 70 Charger fenders.
Thank You
Frank
70 Charger R/T 440 4spd Dana
Re: Factory Under Coat [Re: Frankie P] #2918439
05/04/21 01:41 PM
05/04/21 01:41 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: Factory Under Coat [Re: Frankie P] #2918454
05/04/21 02:17 PM
05/04/21 02:17 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Good advice. I used Restorick's undercoating on my 70. I was able to duplicate the texture and look of the original stuff by playing with air pressure, spray pattern, distance etc using the Dutz spay gun. It touched up the damaged original undercoating nicely and looks original.
Re: Factory Under Coat [Re: Neil] #2918464
05/04/21 02:33 PM
05/04/21 02:33 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Originally Posted by Neil
This stuff! iagree
I have had mine on for seven years, still looking great and holding up well.
My Monster are real!
Living within your means makes life pretty easy.
Re: Factory Under Coat [Re: Frankie P] #2918743
05/05/21 07:13 AM
05/05/21 07:13 AM
Thomaston, CT
Thomaston, CT
Thanks Guys
I'm on the home stretch to paint and will definitely look at Resto Rick
