Never in my life thought Head gaskets. would be so hard to #2917318
05/01/21 12:03 PM
05/01/21 12:03 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Need a set of 4.600 bore .027 or .040 thick or anything in between for a RB
Re: Never in my life thought Head gaskets. would be so hard to [Re: VernMotor] #2917421
05/01/21 04:12 PM
05/01/21 04:12 PM
birdtracker Offline
birdtracker  Offline
Just for suggestions if Jegs or Summit doesn't have them, I have bought Cometic from Ohio Crankshaft and also from Indy Cylinder Head. Both places had 4.50 in stock. Give them a try. Birdtracker
Re: Never in my life thought Head gaskets. would be so hard to [Re: VernMotor] #2917446
05/01/21 04:56 PM
05/01/21 04:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'm thinking you have a lot of chamfer at the top of a 4.500" bore? You might be looking for unobtainium.
Re: Never in my life thought Head gaskets. would be so hard to [Re: John_Kunkel] #2917458
05/01/21 06:48 PM
05/01/21 06:48 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
No it not the bore. it is the camber in the head. they make 4.600 but cosmetic gaskets must be shut down. they say aug before you can get them . 4.500 is right on the edge of the camber ..I don't like it. to close for me.
Re: Never in my life thought Head gaskets. would be so hard to [Re: VernMotor] #2917470
05/01/21 07:58 PM
05/01/21 07:58 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
All I could find in .030's were 2 4.380 bore that summit had. I had to get them ups'd to the border, and the border shipper has been sitting on them for 2 weeks. Hard to beleive that there is only one major mls performance gasket company making the bulk of the gaskets.
Re: Never in my life thought Head gaskets. would be so hard to [Re: VernMotor] #2917477
05/01/21 08:12 PM
05/01/21 08:12 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Check Flatout Gasket. Summit shows a ship date of 6/1. Maybe buying direct would be faster.
Ok
Re: Never in my life thought Head gaskets. would be so hard to [Re: VernMotor] #2917503
05/01/21 09:53 PM
05/01/21 09:53 PM
AndyF Offline
AndyF  Offline
I don't know what happened to Cometic but with them not shipping the racing season might get shorter. Almost every race engine that goes thru the shop I work with gets Cometic gaskets. No gaskets, no engines.
Re: Never in my life thought Head gaskets. would be so hard to [Re: cudatom] #2917504
05/01/21 09:57 PM
05/01/21 09:57 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Well flat out shows 4.520 .030 ship 5/3/21 I think them might work. thanks .. 4.500 are right on the edge of the chamber . so that extra ..020 might be good.
Re: Never in my life thought Head gaskets. would be so hard to [Re: VernMotor] #2917507
05/01/21 10:02 PM
05/01/21 10:02 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Has anyone run a set of these Rubber Coated Copper, head gaskets ?
Re: Never in my life thought Head gaskets. would be so hard to [Re: VernMotor] #2917518
05/01/21 10:50 PM
05/01/21 10:50 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Check the TricK flow gaskets as they are Cometics in Trick Flow packaging. Also Felpro makes a .40 and a .051 in the big block but only for the smaller bore stuff that I can find (they are cheaper than the Cometics) IN the bore size your looking for I got nothing.
Todd
Re: Never in my life thought Head gaskets. would be so hard to [Re: sasquatch] #2917592
05/02/21 09:38 AM
05/02/21 09:38 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Re: Never in my life thought Head gaskets. would be so hard to [Re: Stanton] #2917615
05/02/21 10:43 AM
05/02/21 10:43 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Might try some of the copper companies like Clark. We have had issues with cometic for awhile. They also now seem reluctant to any "custom" stuff as well. I have had to use Clark more than once.
Re: Never in my life thought Head gaskets. would be so hard to [Re: Al_Alguire] #2917650
05/02/21 12:13 PM
05/02/21 12:13 PM
Texas
Chief Offline
Chief  Offline
Texas
I spent a couple of months getting some 4.5 in .080 Cometic.
I called them and was told they make them "to order".
I'm seriously considering to get my heads and block oring'd and just use a copper gasket. A little Hylomar around any liquid passages seals them up.
The Hylomar is what most of the alky guy's use. I have used it in the past when I ran copper gasket and had no leaks.
I run 15 lbs of boost with the cometics and have never had a head gasket problem that is the only reason I'm hesitant to switch
My .02
Dave Covey
Re: Never in my life thought Head gaskets. would be so hard to [Re: Chief] #2917753
05/02/21 04:02 PM
05/02/21 04:02 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I just waited 8 wks for a set of head gasket for a small block mopar unbelievable
Re: Never in my life thought Head gaskets. would be so hard to [Re: scottb] #2918242
05/03/21 10:36 PM
05/03/21 10:36 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Looks like Mr. Gasket has some stock on a few sizes.
Re: Never in my life thought Head gaskets. would be so hard to [Re: Uberpube] #2918420
05/04/21 01:11 PM
05/04/21 01:11 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Did you speak to anyone at Cometic? I've had very good response with getting gaskets direct.
Doug
Re: Never in my life thought Head gaskets. would be so hard to [Re: dvw] #2918427
05/04/21 01:23 PM
05/04/21 01:23 PM
Texas
Chief Offline
Chief  Offline
Texas
Doug
When I called they were working short days, and using less people.
Dave Covey
Re: Never in my life thought Head gaskets. would be so hard to [Re: Chief] #2918431
05/04/21 01:29 PM
05/04/21 01:29 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I will get the straight facts today and report back. I need about 10 sets at the moment.
Todd
Re: Never in my life thought Head gaskets. would be so hard to [Re: sasquatch] #2918443
05/04/21 01:49 PM
05/04/21 01:49 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Most recent set I ordered direct from Cometic took 5 weeks to get. Not to bad considering my pistons took 10 weeks to get from CP
Re: Never in my life thought Head gaskets. would be so hard to [Re: cl440] #2918642
05/04/21 08:45 PM
05/04/21 08:45 PM
portland, ct
Since1822 Offline
Since1822  Offline
portland, ct
Same here waited five weeks
