Brake question #2917359
05/01/21 01:25 PM
05/01/21 01:25 PM
myrtle beach, sc
E
edison1970 Offline OP
E
myrtle beach, sc
I'm having issues with my power brakes on my Barracuda. Factory disc in front and drum in back. Everything is new. Bench bled the master dot 5 used. Bled all four corners until brake pedal was hard. Now I start the car and the pedal pressure drops almost 3/4 down. Could that mean I don't have enough vaccum or the booster is bad? Cam is a Lunati 703. The motor has 15-16 of vaccum at idle.
Re: Brake question [Re: edison1970] #2917387
05/01/21 02:29 PM
05/01/21 02:29 PM
Andrewh Offline
Andrewh  Offline
not sure what you mean by pedal pressure drops.
Re: Brake question [Re: Andrewh] #2917423
05/01/21 04:15 PM
05/01/21 04:15 PM
myrtle beach, sc
E
E
myrtle beach, sc
When I depress the pedal when it's running, the pedal goes down 3/4 of the way before the brakes start to work.
Re: Brake question [Re: edison1970] #2917432
05/01/21 04:35 PM
05/01/21 04:35 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
DOT 5 might be part of the problem. Better for your paint in case of a spill but not for brake feel. Not enough vacuum shouldn't effect travel I don't believe, just hardness of the brakes because less assist.
Facts are stubborn things.
Re: Brake question [Re: edison1970] #2917439
05/01/21 04:44 PM
05/01/21 04:44 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
"everything new"....did you set the proper air gap between the booster and master, you need to reset or confirm anytime you rebuild/replace these components, this may be your issue? Mopar's need a minimum of .020 to a max of .060 for proper operation....
MikeG
Re: Brake question [Re: edison1970] #2917443
05/01/21 04:50 PM
05/01/21 04:50 PM
Andrewh Offline
Andrewh  Offline
it could also be adjusment of the rear brakes.
if you don't hear dragging when you spin the wheels, the shoes are out of adjustment. which will cause what you describe as well.
Re: Brake question [Re: edison1970] #2917444
05/01/21 04:52 PM
05/01/21 04:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the pedal drops with the engine running, vacuum isn't your problem....the booster is working.
Have you adjusted the rear shoes for a slight drag when turning the wheel? Loose drum brakes will eat up a lot of pedal travel.
Re: Brake question [Re: Andrewh] #2917449
05/01/21 05:00 PM
05/01/21 05:00 PM
myrtle beach, sc
E
E
myrtle beach, sc
I'll double check the rod length and check the rear drums and let you know what happens. Thanks guys.
Re: Brake question [Re: John_Kunkel] #2917450
05/01/21 05:03 PM
05/01/21 05:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree
Every late model power disc brake and 4 wheel drum brake Mopar car I've driven will do what yours is doing up
the pedal should be really hard to push with the motor off and no vacuum, easy when running and driving, hence the "power brake" name thumbs
Re: Brake question [Re: Cab_Burge] #2917569
05/02/21 08:28 AM
05/02/21 08:28 AM
VA
dragon slayer Offline
VA
Not 3/4" of the way down on my cars.
Re: Brake question [Re: dragon slayer] #2920925
05/10/21 08:43 PM
05/10/21 08:43 PM
myrtle beach, sc
E
E
myrtle beach, sc
I appreciate the info guys. I finally got it worked out. I bled all four corners again. Then adjusted the rear drums and the booster rod. After all of that, it was better but not 100%. I decided to take the linkage that attaches to the pivot from the booster to the brake pedal and modify it. I cut it in half and put a threaded stud between the to ends making the length adjustable. By making slightly longer made the brakes work like they should.
