Re: Replacing sending unit in-cab tank [Re: hp383] #2916598
04/29/21 03:48 PM
04/29/21 03:48 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Larry this is a 15 minute job just do it.
Re: Replacing sending unit in-cab tank [Re: stumpy] #2916870
04/30/21 09:45 AM
04/30/21 09:45 AM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I understand the sentiment but I’m still waiting on part anyway. Should be here today or tomorrow.
New one I bought says all are tested for proper ohms for accuracy and quality.
Looking again at my current one I believe someone installed lock ring upside down?
Facts are stubborn things.
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2916876
04/30/21 09:55 AM
04/30/21 09:55 AM
N
NITROUSN Offline
NITROUSN  Offline
N
It is on right but not tight.
Re: Replacing sending unit in-cab tank [Re: NITROUSN] #2916877
04/30/21 09:57 AM
04/30/21 09:57 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
You sure? I just removed it. Ring was bent down at lip as if to make it fit under locking lip on tank
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2916952
04/30/21 12:14 PM
04/30/21 12:14 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
You are correct, it was on Upside down
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Replacing sending unit in-cab tank [Re: W.I.N. Racing] #2916979
04/30/21 01:19 PM
04/30/21 01:19 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Yup my bad. I Thought by the picture it looked to be ok. You would think it would be a no brainer on which way it goes. First time for everything.
Re: Replacing sending unit in-cab tank [Re: NITROUSN] #2917003
04/30/21 02:10 PM
04/30/21 02:10 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
The guy that had the truck before me left a lot of things half-azzed. Thanks for assist.
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2918912
05/05/21 03:28 PM
05/05/21 03:28 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I installed sender and lock ring (proper way this time) and now I realize wire was supposed to have a push on connector like one in this picture but it's long gone. I'd like to find another but no luck local parts store or Feebay. I've googled "push on connectors" and so far I don't find. Any specialties stores online anyone knows of? Driving around town looking doesn't sound fun. Stud is M5 - .08. Thanks.
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2918921
05/05/21 03:43 PM
05/05/21 03:43 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
go to a napa and find the electrical connector guru or book. some ford temp/oil sending units are the same style but not overshielded like that one. i have used them before with great success.
Re: Replacing sending unit in-cab tank [Re: trw1982] #2918947
05/05/21 04:46 PM
05/05/21 04:46 PM
Grand Prairie,Texas
Grand Prairie,Texas
I have used butt connecters to replace push on terminals.
Re: Replacing sending unit in-cab tank [Re: stumpy] #2918954
05/05/21 05:01 PM
05/05/21 05:01 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thanks for the suggestion guys. I wondered about the oil sending unit connectors but none of them list a size. I used to have a bunch of the stuff and I just recently decided to make some more room in the garage and of course now I need one LOL. I tried a connector and nut but the nut does not tighten down tight. I’m going to try o/p sender next 👍
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2918957
05/05/21 05:02 PM
05/05/21 05:02 PM
Grand Prairie,Texas
Grand Prairie,Texas
Re: Replacing sending unit in-cab tank [Re: stumpy] #2918963
05/05/21 05:11 PM
05/05/21 05:11 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Pricy but it would work.
https://www.ebay.com/itm/192938234195?
I wouldn’t mind spending this and if the oil sending unit ones aren’t the right size I’ll give this a try. I’m ready to be done with this and move on to other things. I didn’t plan on this being a project. Thanks again.
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2919031
05/05/21 08:05 PM
05/05/21 08:05 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
the one from napa will be a tad smaller but have threads inside it to hold it on tight so it wont lose connection. i have done this before .works great.
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2919043
05/05/21 08:16 PM
05/05/21 08:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
One from the older single wire engine coolant sensors should also work.
Re: Replacing sending unit in-cab tank [Re: NITROUSN] #2919152
05/06/21 12:45 AM
05/06/21 12:45 AM
5thAve Offline
5thAve  Offline
I've also used a but conncetor on those things before and squished them with pliers a bit if they were too loose.
Re: Replacing sending unit in-cab tank [Re: 5thAve] #2919404
05/06/21 04:20 PM
05/06/21 04:20 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Found one on Feebay with help of seller of sending unit. It's listed for A-B-C body cars as repair wire but will fit my truck sender. Woo hoo. I tried all kinds of searches but none included A-B-C body so it didn't come up. $15 and on the way.
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2922530
05/14/21 04:36 PM
05/14/21 04:36 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
The plug from vansauto feels very high quality, factory style and fits very snug AND as you can see came with lengthy wire. So glad I was directed there. If yours needs replacing I highly recommend this one and it was under $20. up No more gas smell even when the tank is full and I’m getting accurate readings.
Re: Replacing sending unit in-cab tank [Re: larrymopar360] #2922642
05/14/21 10:54 PM
05/14/21 10:54 PM
Grand Prairie,Texas
Grand Prairie,Texas
Good deal. up
