Re: e-body space saver wheel
[Re: GVH]
#2915686
04/27/21 01:24 PM
04/27/21 01:24 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
Mine has 5 holes June 14 /71 build Also, could you post a picture of the valve stem area with date code please. I will dig up mine and post also.
[Re: sbcjd]
#2915915
04/27/21 10:09 PM
04/27/21 10:09 PM
Posts: 5,120 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Chrysler likely ran out of all those 1970 Rims and thought why not use the 5 hole now instead of the 6 hole. Lot of changes during the 1971 build and a lot at the end of the year.
1971 HEMI E BODY REGISTRY
[Re: sbcjd]
#2917505
05/01/21 09:58 PM
05/01/21 09:58 PM
Posts: 302 Ontario, Canada
GVH
Ontario, Canada
My camera is MIA, but the numbers by the valve stem are K11 2 25 5.5 and there is no white paint dab When was your car built ? Mine is June 14 th.
[Re: mccannix]
#2917619
05/02/21 10:49 AM
05/02/21 10:49 AM
Posts: 43,594 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
That F-78-14 B.F. Goodrich is a good one Jim. Tire and rim are Ford set-up...good for the 70 Shelby and Boss crowd. Tire has the all important V-1. Tire could be switched onto a correct Mopar rim for E-bodies, but is worth as much or more as is on the Ford rim. Bottle and bracket are reproduction for E-body Thanks! I didn't think it was Mopar, but not well versed on these space savers. Thought the canister looked to good to be original...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2917645
05/02/21 12:02 PM
05/02/21 12:02 PM
Posts: 19,488 north of coder
moparx
i junked a 76 newyorker one time that had a space saver spare. i can't remember the tire size nor the manufacturer, but the bottle and hold down clamp were very close to the blue color of the hold down shown. i thought it odd that a C-body would have a space saver spare. the size was larger than an F-78, and as the trunk was very well preserved and the car was a low mileage [20something k, but was junked because of severe rust] piece, it sure looked like the space saver was original to the car. the wheel was never used so the tire was removed [what FUN that was !] and since the wheel was full size, a full size tire was mounted then used on whatever we had going at the time.
